![]() Drives: Yaris S 5dr hatch 09 Join Date: Jun 2010
spring compression plz read need answers
ok i have a yaris 5dr hatch09 i brought springs for it from DZ it was a 1.8 all around...but then when i had them installed the car was more lowered in the back then the front.....so this guy called saying not to cut them but that he can compress the spring so that it will match like the rear but the question is is that a good idea to do i really need answers please and thanks
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Let the new suspension settle for a few weeks- 2 months max. The way our suspension is designed stock it has a slight rake. When some springs are put on it makes it seem like the back is lower then the front. Pretty typical with springs that drop the same height front and back. Mine looked like that for about 2 weeks after I dropped mine. Just let it settle itself in and you should be good. Just dont cut the springs.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
If all else fails you might contact a commercial spring shop. They typically service heavy trucks and may be able to help re-configure your rear springs.
Good Luck!
Spring spacers will raise the rear approximately 3/8" and stiffen it slightly.
This thread has two to pick from: http://www.microimageonline.com/foru...ing-stiffeners
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you could do some water-hose or similar hose on the spring on each end. not only will it stop squeaks but it will also raise vehicle a little. not much or anything significant but it will raise. you could also go on the self help aisle in autozone or similar and find some spring spacers....get the small ones. they twist in using 1/2" square driver. it's a rig job i know, but they're like 10 bux for 4 of them...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Just saw this. I run the "compressed spring clamp" on the front springs to lower my DF210's a little. Works great but you will (of course) get a little more bounce.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| About spring rates... | SaerinRhoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 11-13-2009 05:08 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Track Suspension | id3379 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 85 | 06-11-2009 05:59 PM |
