Cruise Control on 2010 Canadian Manual
Hello,
I want to install Cruise Control on my 2010 Canadian Manual. I want to use original parts. My car has electronic tachometer. What is the procedure for finding the right parts for my car? I looked at PeteZNY's topic at http://www.yarisworld.com/forums/sho...cruise+control But i don't know does the same parts work for me. I looked at my tachometer with a bright light. I can see the lights for the accessories i never used. (they don't light but they appear under bright light) but I couldn't see the cruise control lights. I looked at CTScott topic for Cruise Control FAQ at http://www.yarisworld.com/forums/showthread.php?t=25515 but i'm not sure if cruise control works for me because i couldn't find the cruise control lamp. I'll be glad if you help. Thanks. |
Hello again,
I found 84632-34011 on ebay, and just ordered it. I couldn't find other parts at the moment. I'm searching. |
Hello,
I just disassambled my tachometer to see the lights but I don't have the cruise control lights! my tachometer photos are attached. and I'm attaching the connector photos. Last edited by Kaya B.; 09-24-2010 at 01:10 PM. |
It definitely won't work on yours.
Your car is not a Canadian one - Based on the wiring and the cluster, I would suspect that it is a European one. |
#5 | |
I bought it brand new. It is the LS package. Built for the Canadian market and sent to Turkey. Differences from Turkish model are; heated seats, bluetooth, manual rear windows, daytime running lights and no start&stop system. I'm sure it is Canadian. And I've already purchased the cruise control stalk :( Also; authorized dealer asks for 250$ to install cruise control. |
Canadian market does not get the digital cluster.
Outside of my knowledge and experience. This is where I go
![]() Sorry
If you PM me your VIN, I can run it through the international EPC and figure out what market your car is actually from, but just having the digital cluster and the wiring for steering wheel audio controls means that your ECM does not have the cruise control functionality.
thanks all.
I learned that the LS package cars came especially digital cluster because there were no analog clusters in Turkey. they came with another package in the half of 2010 called terra sporty |
#11 | |
Your Yaris was made in France (in the TMMF plant) in December of 2008. It is a European Terra Type. So, no easy cruise control for you. |
#13 | |
Check out the link below. This Belgium based company makes an aftermarket CC for European Toyotas: http://www.el-pas.com/products.htm |
#14 | |
Also, I'm talking with the authorized dealer. they say they can make... |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
Scott will check also my vin ? please
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 10:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
