![]() Drives: Yaris 2003 Join Date: Apr 2010
Help with Loose Handbrake
Hi,
Could any of you tell me how easy is it to adjust the handbrake on a 2003 yaris. When I first pull up the handbrake it doesn’t hold the car sufficiently and if on a slight incline it begins to roll. I have to then pull the handbrake up to it’s highest possible point to have any effect. Is it possible to tighten the handbrake. Thanks for any advice. Roth
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
You gotta take off rear drums and turn the little star looking wheel. Use a flat head screwdriver and turn both sides left wheel and right wheel evenly. Brake shoes may be worn out if handle moving that high also. You can find a DIY for adjusting brakes if you type that in search box that is how I learned lol.
Just remember turn 2-3 clicks at a time. I am not sure how to back if off if you get too tight brakes may drag |
#3 | |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
I just had mine adjusted, holds the car after 2 clicks of pulling the e-brake lever. |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Yeah, you don't have to take the wheels and drums off to adjust the shoes in the rear. There should be a rubber plug in the backside of the brake shield. Take that off, shine a flashlight in, and find the wheel to turn.
| Handbrake Loose | Roth5150 | General Yaris / Vitz Discussion | 1 | 09-12-2011 10:03 PM |
| how to break loose pulley bolt | yaris9876 | DIY / Maintenance / Service | 10 | 05-16-2010 02:55 PM |
| Had my brakes done....now handbrake is harder to pull. | captainm27 | General Yaris / Vitz Discussion | 7 | 05-10-2010 08:00 PM |
| Loose shifter knob | dvspindler | Cosmetic Modifications (Exterior/Interior) | 7 | 08-06-2009 05:07 PM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 07:37 PM |
