![]() Drives: 2012 Super White Yaris SE Join Date: Nov 2011
DIY: 2012 Radio Removal
Tools Needed:
1.Kung Fu Grip 2.8mm Socket, Extension, and Ratchet(I Used 8mm Screw Driver) or Philips #2 Screw driver Step 1. Starting on the right side of vehicle(Passenger side USDM) pull the surround panel using your kung fu grip by the a/c vent. It is held in by clips all the way around. After you loosen the first clip just pull gently all the way around. ![]() Step 2. Pull the surround out around the radio. Held in by clips similar to the dash panel. ![]() Step 3. (Optional) Remove the connector for Hazard Switch. (I left it connected and let it hang) ![]() Step 4. Unscrew the Radio using your tool of choice.(Yellow dots, 2 screws on each side) ![]() ![]() Step 5. Pull the radio out and remove connectors. ![]()
$10.25/hr frying chicken
very nice. what are you going to put in instead?
The stock radio actually has everything I need, Ipod integration, Bluetooth Phone and Audio(I can even stream Pandora and watch youtube and it will play through the car speakers with the display of the text of whats playing.) I can use a USB Thumb drive, or just a regular aux port. It has HD Radio(You have to let it switch to HD mode and then there will be a 1/2 or a 2/2 in the top right corner to switch stations. It took me a while to figure that out.) I was actually tapping the wires for a subwoofer out. The only reason I would switch out the factory headunit would be for a Navigation display. I'm waiting for the Prius C to come out and see if that radio would be compatible.
![]() ![]() Drives: Black 2012 Yaris 3door 5speed Join Date: Dec 2011
No but if you still have access to a G.I. Joe, you'll be good.
New to the Toyota World, be nice. |
| DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 306 | 08-02-2026 02:50 PM |
| DIY amp wire running and radio trim removal | Slick | In Car Entertainment + Electronics (audio / video / alarm) | 30 | 06-28-2026 01:44 PM |
| DIY: 2012 Front Bumper Removal | vrwm | Third Gen Yaris General Discussion | 15 | 07-19-2013 05:23 AM |
| DIY amp wire running and radio trim removal | Slick | DIY / Maintenance / Service | 0 | 09-10-2009 08:00 PM |
