![]() ![]() Drives: yaris sedan type s Join Date: Sep 2009
headlights out! :(
hey u guys i need help...i was driving home in the country side with my high beam and my lights just went out(low beam + high beam out). just checked the fuses today but theyre fine so i think i might get some new fuses to switch them just in case but does anyone have any ideas or suggestions about what the cause of the problem is?
There are two separate fuses for the two sides H-LP RH and H-LP LH.
Does the headlight icon light up on the cluster?
Check the ECU-B fuse in the under hood fuse panel.
The high beam indicator is separate from the headlights on indicator. The headlights on one is driven by the control side of the circuit and the high beam indicator is driven by power flowing through the bulbs, so if both bulbs were bad, that would be one possible explanation.
Besides verifying that both bulbs aren't completely bad, check the H-LP/AMT Relay in the little box on the passenger side, under the hood. Have someone else turn the headlight switch on and off, while you listen closely for the relay to click as they do.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 03:31 AM |
| 2010 yaris Projector headlights | yaris2010RS | Items for Sale by private party | 9 | 01-09-2012 06:31 PM |
| Headlights | Dpudg | General Yaris / Vitz Discussion | 5 | 09-04-2011 04:18 PM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 07:50 PM |
