Old 06-05-2012, 01:20 AM   #1
TOLMACH
Drives: soarer
TRD rear sway bar installed
(One more review)
Background: completely stock suspension (struts + springs). TRD rear sway bar installed (bought from TRDsparks)
Impressions: nice thing, definitely can feel its presence. Car became a bit sharper. Like this thing a lot. The thing is firm and sturdy - played with it a little before installation (I am kinda strong 215 lbs guy). Overall a great mod for 150 bucks.
Installation is very straightforward and easy. Also liked the trdsparks customer service - guys seem to be busting their asses (in a good sense).
Old 06-05-2012, 02:03 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'm totally satisfied with mine as well. It tucks neatly up into the framework...
It's one of the best bang for the buck mods for a Yaris.
Old 06-05-2012, 02:45 AM   #3
TOLMACH
Drives: soarer
Especially considering UR became overpriced and this one is only 150 bucks
Old 06-05-2012, 03:17 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I have one sitting in the shed, waiting for the rest of the suspension parts to show up before I put it on...
Old 06-05-2012, 07:15 AM   #5
racerb
My UR 23mm bar has been ordered just wiating for it to arrive. I would have gone TRD, but I plan to Auto-X the Yaris and wanted the larger bar, hopefully decrease the understeer. Looks good by the way!!
PS: Sparks Toyota (TRD Sparks) is less than an hour from my house, so I do plan on getting some TRD and stock parts from them!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 06-05-2012, 07:58 AM   #6
CrankyOldMan
I ended up getting the TRD but for the same reason: if you put on the TRD, it counts as a port option for SCCA AutoX--leaving you the option of adding a larger front bar. The larger bar, of course, will be coming from those beautiful folks at MI.
Old 06-05-2012, 08:34 AM   #7
racerb
Not sure yet, but having a larger front bar has never been an issue on any of my previous FWD Auto-X and/or Road Race machines. Having the biggest rear bar I could find made the biggest difference, in fact the last car I built (Nissan) we removed the front bar completely. No more understeer and the LSD actually did it's job much better, with less camber needed!!
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 06-05-2012, 12:13 PM   #8
Jason@SportsCar
There is more then one OE front bar as well. We pulled off the stock 24mm bar and used a smaller 23mm we got from a 2007 sedan to help rotation. The 24mm has a blue dot, the 23mm has a purple dot.
http://www.yarisworld.com/forums/sho...&postcount=749
Old 06-05-2012, 02:27 PM   #9
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I'm running the trd bar and would probably go to a bigger bar if I could do it over.
To add to this I pulled my front bar off last weekend to get an idea of how the car behaved with it missing, and it wasn't doom and gloom like I expected plus my times were something in the range of 2 seconds faster on a 60 second course this is also with running -.8 camber vs the normal -2.7 I usually run.
Going over my data I definitely lost lateral traction something like 0.05g but I was able to get on the gas so much earlier that the slight loss in lateral traction didn't matter. I wouldn't recommend this for anyone unless they were running much stiffer springs since body roll increased dramatically. Also I was having problems with rubbing as well as the car became quite a bit more loose and would oversteer on trail braking which is good for me since I don't left foot brake.
Old 06-05-2012, 02:59 PM   #10
racerb
To add to this I pulled my front bar off last weekend to get an idea of how the car behaved with it missing, and it wasn't doom and gloom like I expected plus my times were something in the range of 2 seconds improved on a 60 second course this is also with running -.8 camber vs the normal -2.7 I usually run.
Understood, by the time we got to the point of disconnecting the front bar, we were running Koni inserts in custom housings with adjustible coil-overs and camber plates. Rear was set up with inverted Carreras with in-board lowering springs and 7/8" adjustible rear bar, also the tranny had a 4 puck clutch disk, 800 kg pressure plate and Phantom-Grip LSD unit. Car handled like a go-cart, but could barely outrun it's own shadow, still fun to race though!!
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 06-05-2012, 08:54 AM   #11
richard_rsp
richard_rsp's Avatar
Drives: 2012 Yaris L 3Dr
Glad to hear you enjoy it! I bought one for my 2012 (from TRDSparks) yesterday... Should be delivered tomorrow!
richard_rsp is offline   Reply With Quote
Old 06-05-2012, 10:20 AM   #12
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
drop it now for ultimate handling
Old 06-05-2012, 10:23 AM   #13
Sparks Toyota-TRD
Drives: Toyota/Scion
Thank you for the orders gents! We really appreciate the business and these cars are fun to drive when the suspension is modified! I have an 06 xB with highly modified suspension and have a blast everyday driving it.
Sparks Toyota-TRD is offline   Reply With Quote
Old 06-05-2012, 09:44 PM   #14
TOLMACH
Drives: soarer
Looking forward to receiving my TRD cold air intake (I think it was you who processed my order earlier today)
Old 06-05-2012, 11:28 AM   #15
^ Sparks, you should become a vendor again, this market is clearly still viable for you!
Old 06-05-2012, 11:47 AM   #16
Sparks Toyota-TRD
Wish we could, but the forum died a little as well pricing went up! We are still hanging around here!
Old 06-05-2012, 12:10 PM   #17
Bethlehem-yaris
Black 3 door
Bethlehem-yaris's Avatar
Drives: 2011 3DR BLACK YARIS
gona sound like a dork.... what does it do?
Bethlehem-yaris is offline   Reply With Quote
Old 06-05-2012, 09:51 PM   #18
TOLMACH
Drives: soarer
This is a nice thing to reduce the body roll and make the car handling a bit sharper. The result in my case exceeded my expectations.
There are lots of posts here on installation of the rear sway bars.
Got new TRD sway bar! caineroad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-24-2009 10:55 AM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
Installed TRD Strut + Sway bar Blenjar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-10-2007 11:46 PM
