![]() Drives: Yaris RS 2007 Join Date: Apr 2012
Hi,
I've waited a long time before posting about this problem trying to fix it on my own but now i'm at a dead end and im open to pretty much any advice, I have a 2007 hatch and when the engine is warmed up and i'm stopped at idle for about a minute I get a high pitch noise that comes from the engine bay. Ive tried to film it (http://www.youtube.com/watch?v=vTiOPe6qmAg), without much success.. It sounds like a vacuum leak but even when I sprayed starter fluid on the vacuum lines it didn't affect anything ...the car tries to stall and the engine shakes in a way i dont really like Then when the radiator fan comes on the idle goes up a bit and the noise disappears. As soon as the fan shuts down it starts again I look foward to your advice thanks
So you fixed it?
Not yet, still looking around for possible issues linked to that, i notice it runs lean when it runs badly, checked my upstream O2 and the resistances aren as specified in the repair manual so that might be it
have you ever heard of something like that? |
Have you checked to make sure the. Heat shield isn't loose. It'll make a squeaking sound like that.
And you need to check voltage on the front sensor not resistance to determain your reading. |
#5 | |
and the heat shield does not move at all
Those resistance values are for an unplugged sensor to make sure it's within static value. Those are not for when the car is running plugged in. So in order to read rich or lean you need to measure the output voltage of the sensor.
#7 | |
The ECM maintains a constant voltage on the sensor and it measures the current required to maintain that constant voltage to determine AFR. So, if you measure the voltage on the sensor it will always read the same unless there is something wrong with the circuit within the ECM.
I guess I'm not up to date with how the Yaris ECU works, just the Echo.
If I unplug the AFR meter on the exhaust manifold I'm assuming that the ECU will switch to fault mode and run from a baseline set by Toyota ? If so, if I unplug it and the car runs fine it just means that I have to change the sensor?
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Hard to tell much from the video. Try hitting the exhaust with your hand or a soft mallet. See if you get any rattles. Also while cold, take your finger and pull on the manifold heat shield etc and try to "twang" it like a guitar string to get a noise. Often the best way to find loose heat shields. Just watch for sharp edges.
Other things that come to mind: -cracked exhaust -plugged cat or broken baffle in muffler causing intermittent plugging (but would expect to notice this driving, not at idle) Any other engine problems with the car? Is it stock? |
#12 | |
Ok, I have another idea... I too ran a straight pipe axle back for a while and tho it was cool and loud, It also set missfire code because the joint was loose, at idle. Make sure all the joints in the exhaust system are tight. It was doing the exact same thing at idle, minus the noise. The revs were dropping because it was pulling timing back.
#14 |
Ok. Leaking exhaust before, or sometimes up to a foot behind the pre-cat O2 sensor can suck in oxygen and confuse the computer. Also rattles can be picked up by the knock sensor, which will then cause the computer to pull timing out. Either could cause the poor idle issue.
#15 | |
and the timing is pulled back to 2.5 degrees instead of 5 like it normally does
#16 |
try re-installing the stock muffler and see if that fixes the problem. Maybe the knock sensor is overly sensitive.
#17 |
#18 |
Is there any way to bypass the knock sensors for testing purpose?
| vitz high idle problem after cleaning the throttle body. | dindy | DIY / Maintenance / Service | 20 | 11-07-2012 06:05 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| chirp/squeak noise just off idle when cold | tadc | DIY / Maintenance / Service | 14 | 02-20-2011 04:09 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 06:40 PM |
| high pitch whine at 100km/h | Moore | General Yaris / Vitz Discussion | 9 | 06-11-2007 08:22 PM |
