Old 12-20-2012, 12:27 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Ok, I have another idea... I too ran a straight pipe axle back for a while and tho it was cool and loud, It also set missfire code because the joint was loose, at idle. Make sure all the joints in the exhaust system are tight. It was doing the exact same thing at idle, minus the noise. The revs were dropping because it was pulling timing back.
Old 12-21-2012, 01:07 PM   #2
mokmok
Drives: Yaris RS 2007
The joints are tight and the exhaust heat shild is well held in place, but i'm starting to think that my rusted out headers are somehow leaking but why wouldnt it leak when cold... and the timing is pulled back to 2.5 degrees instead of 5 like it normally does
mokmok is offline   Reply With Quote
vitz high idle problem after cleaning the throttle body. dindy DIY / Maintenance / Service 20 11-07-2012 05:05 PM
chirp/squeak noise just off idle when cold tadc DIY / Maintenance / Service 14 02-20-2011 03:09 PM
annoyin noise (ticking or rattling) on idle.. abdallah380 DIY / Maintenance / Service 2 04-18-2009 05:40 PM
high pitch whine at 100km/h Moore General Yaris / Vitz Discussion 9 06-11-2007 07:22 PM
