Old 02-28-2013, 02:19 PM   #1
Mikastef
Drives: Yaris
front fan knob broken? pls help
Dear all,
I have a toyota yaris year 2006.
I recently tried to move my fan air circulation from outside to recirculate. However, the knob got stuck and while trying to unstuck them, it broke down. I cannot change the air management option anymore and it is stuck on recirculate air.
I have looked into youtube and some forum and noted someone has been able to repair this knob by removing the front cover and by replugging the connector.
However I am unable to remove the front cover of the fan. I have been able to remove only the side cover, but the front cover seems to be stuck by the radio cover, which seems impossible to dislodge, without first unscrewing the radio.
Can anymore please help me out there, you will be of tremendous help
Thank you
Michael
Mikastef is offline   Reply With Quote
Old 02-28-2013, 02:22 PM   #2
Mikastef
Drives: Yaris
find attached a picture of my dashboard
Old 02-28-2013, 02:32 PM   #3
You just need to pull off those black vertical pieces first. Get your fingers under the bottom edge by the storage pocket and pull out. Once they are off, the silver piece with the knobs pulls straight off.
Old 02-28-2013, 03:06 PM   #4
Mikastef
Drives: Yaris
hi. I have indeed been able to remove the vertical pieces with no problem (number 1 & 2 as per picture above). However the number 3 should be removed to access the knob. since when I check the knob cover, it seems that it is in fact clip also to the radio cover.
Old 02-28-2013, 03:40 PM   #5
That is correct. You will need to remove the radio mounting screws and pull the radio forward a bit to allow the AC panel to come off.
Old 02-28-2013, 03:32 PM   #6
Not exactly the same trim as yours, but the fasteners will all be the same. This link will show you how the instrument cluster trim and the radio bezel clip together.
http://www.yarisworld.com/forums/sho...7&postcount=17
Old 06-15-2014, 04:34 AM   #7
Mikastef
Drives: Yaris
Thank you everyone !so helpful :) !
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 05:48 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 01:57 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 01:04 PM
FS: OEM shocks, springs, front emblem, lug nuts, Delrin shift knob Brentorius Items for Sale by private party 4 04-06-2010 08:40 AM
