Old 12-19-2015, 12:39 PM   #1
Daddie Y
Drives: 2008 VITZ
FS: Rockford Fosgate Woofer
10 inch woofer with box (PM for more info)
Rockford Fosgate Prime R1 10? subwoofers provide high performance bass at an unbelievable value. This model features a laser etched curvilinear dust-cap to dissipate heat generated by the high?temp copper voice coil as well as a solid stamped steel frame with integrated frame mounted compression terminals. Best of all, they are optimized for both sealed and vented enclosures.
The R1S4-10 features a 4-Ohm Single Voice Coil design, 200 Watt RMS power handling, and is optimized for both sealed and vented enclosures.
Fiber reinforced painted paper-pulp cone
Laser-etched aluminum dustcap
High durability compressed foam surround
Fatigue resistant poly-cotton spider with integral woven leads
Proprietary powder coated stamped steel frame with spider cavity venting
Bumped backplate with vented pole piece for greater thermal/mechanical power handling
High-temp copper voice coil with aluminum former
High-grade Y30 Ferrite magnet
Integrated spring-loaded nickel-plated push terminals
Integrated ABS decorative trim ring
Daddie Y is offline
Old 12-27-2015, 04:39 AM   #2
Daddie Y
Drives: 2008 VITZ
BUMP
Daddie Y is offline
Custom Lift Back Hidden Sealed Woofer Box TinyGiant DIY / Maintenance / Service 42 04-15-2010 03:36 PM
Rockford Fosgate 5.25" Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 1 03-25-2010 02:12 PM
Feeler: Custom HB Woofer Boxes. TinyGiant Items for Sale by private party 27 10-05-2009 10:30 PM
Rockford Fosgate or Alpine? dccurrent In Car Entertainment + Electronics (audio / video / alarm) 2 03-16-2009 11:16 PM
Woofer Mounting question TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 15 10-31-2008 11:43 PM
