Old 07-03-2019, 07:00 PM   #1
sv650steve
Drives: accord (for now)
So I need flywheel options.
I was going to get the comp but they are low on stock. I want a lightweight one. How much can you shave the stock? Anyone got specs on that and what kinda weight I'd get?
sv650steve is offline   Reply With Quote
Old 07-18-2019, 09:39 PM   #2
SirDigby
Drives: 2007 yaris 3 door
that is the one you want. the 8.8 one is great, but it's kinda a single use, as it is not recommended you service it as it's already shaved to maximum thinness. the street one is pretty good at 11 lbs, and it is serviceable. just make sure whatever brand you choose, that it has a steel starter ring. if it's all aluminum the starter will tear off the teeth and you will have starting issues.
9-11 lbs is good weight. if you are forced induction, you could go even lighter, but remember the more weight you shave off, the more torque you loose and it could cause issues wile decelerating....
Old 07-19-2019, 10:31 AM   #3
tmontague
tmontague's Avatar
No torque is lost with a lightweight flywheel what you lose is inertia of the flywheel/engine so the rpm's drop faster between shift which typically translates into not as smooth driving. Torque is a result of the leverage a piston has on the crankshaft (bore and stroke) a different weight of flywheel should not effect that
Old 07-20-2019, 02:06 AM   #4
SirDigby
here is the math.
angler velocity is lost the more weight is removed from flywheel. the more pressure is needed to complete the rotation of the crankshaft. i'm not saying it's drastic, but it is present.
https://vlab.amrita.edu/?sub=1&brch=74&sim=1517&cnt=1
Old 07-20-2019, 10:01 AM   #5
tmontague
tmontague's Avatar
The article you linked to shows the math as torque=force x perpendicular distance to the axis. In the case in an engine, more force is required to move a heavier flywheel which means more torque needed to be applied by the engine to accelerate the car the same rate as a car with a lightweight flywheel. This doesn't translate into the engine having more torque.
This is no different than more torque needs to move a car with heavier wheels, it doesn't mean that car has more torque, it is a negative thing because it requires more torque to move the car.
Old 08-27-2019, 09:44 PM   #6
SirDigby
idk where you purchase from. i just ordered one on sunday from carid.com and it shipped on tuesday...
Old 08-27-2019, 09:47 PM   #7
SirDigby
also i was wrong. the "street" one is 9.45lbs and the ultra-light is 8.8lbs (i'm pretty sure)
just make sure it's made of steel. aluminum is not a good idea for a flywheel.
clutch masters has a good one too for sale everywhere...
Old 08-28-2019, 03:04 PM   #8
suprf1y
suprf1y's Avatar
Drives: 05 Echo
Nothing wrong with an aluminum FW. It will likely have a steel insert for the friction surface.
suprf1y is offline   Reply With Quote
Old 08-28-2019, 01:20 PM   #9
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
My sponsor sells this Fidanza Performance lightweight flywheel as a direct fit option. They also have some universal fit options.
If it makes sense, I have a discount code I can give you for 15% off.
On Instagram
On Wheelwell
Old 08-28-2019, 05:30 PM   #10
Oh really?
Old 08-30-2019, 01:03 PM   #11
ern-diz
ern-diz's Avatar
Oh really?
Yes, sir
If you purchase something, use TWW-EMCEEPROTECH in the promo code section to get my 15% friend/family discount. They don't have a ton of direct fit parts for the Yaris, but they have some and als sell a bunch of performance parts for all different makes so if it makes sense for you, feel free.
I hope I'm not violating forum sponsor/vendor rules by offering this. Not actively pushing it, just offering it from one guy to another. Also, I'm not sure anyone even cares anymore lol. Either way, if this post needs to be deleted, so be it.
On Instagram
On Wheelwell
Old 09-09-2019, 11:43 PM   #12
SirDigby
ha! i just received a notice that they are on back order until december! i guess i was wrong. i contacted a few other places. we'll see what i can find.
i do not trust an aluminum flywheel. i thought there was racing regulations against them, but i can not seem to find any so i guess i was wrong. i've heard of issues with them cracking and exploding. i will stick with steel cause i'm old...
Old 09-10-2019, 08:59 AM   #13
suprf1y
suprf1y's Avatar
Drives: 05 Echo
A lightweight aluminum FW will be much safer than a stock FW
Old 09-10-2019, 06:28 PM   #14
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I went with a monkey wrench racing lightened steel unit. Rev hang is significantly less. When starting off in first, it's touchy. Too much gas and you're hitting 3000rpm. Better be quick shifting from 4-5th gear at lower speeds or you'll have to give it a shot of gas before letting the clutch out to prevent the jerking that comes with a lower rpm than your speed is equivalent to for that gear. Over all happy with the wheel.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
2zr Monkey Wrench Racing Light Weight Flywheel Review tmontague Performance Modifications 15 01-09-2019 02:51 AM
clutch install & flywheel questions So Cal xb visitor Performance Modifications 3 11-04-2013 11:43 AM
Questions for new flywheel and clutch mrbond Performance Modifications 11 07-11-2013 08:17 AM
Flywheel question-1nz conversion-2003 Model Echo56 DIY / Maintenance / Service 0 05-21-2013 11:42 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 02:52 PM
