![]() ![]() Drives: 2013 Hybrid 1.5L T4 Join Date: Jan 2011
Actual Spare Wheel - question
Am thinking of putting in an actual space saver spare wheel, instead of the puncture kit that came with the hybrid.
Thing is, am only finding space saver 14inch ones, whilst mine come with 15inchers. Is it a No-Go, should I still get a 14inch stepney? Thanks for your feedback. Ian - Malta |
Doesn't matter what the OE actual wheel sizing is, the space savers are always smaller. 14" is what you want.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
We must be different here "down under". Our space saver spare is a 16x4 wheel with a 125/70x16 tyre. it's recommended inflation pressure is 60 PSI.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
That's what we get as a spare. It's a "space saver" - 16x4 rim with a 125/70x16 tyre.
The base model has the 2NZ-FE and until recently had 14 inch wheels with 175/70x14 tyres, and the upmarket models have the 1NZ-FE wrih 15 inch wheels and 175/65x15 tyres. Both get the same size spare, which is marked as being speed limited to 80 km/h (50mph). The spare is recommended to only be used on the rear, so if you get a flat front,vyou are supposed to swap a rear tyre to the front, and put the spare on the back.
#7 | |
Yes, but....
The narrow space saver will have less grip. This could be aproblem on the driving wheels. The differnece in diameter can also affect the anti lock brakes It's basically an emergency measure to get you to the nearest tyre shop.
Let me check mine out. There shouldn't me diameter difference
Sent from my SM-G930W8 using Tapatalk |
space saver spare tire
2007 manual lists 14 and 15 inch stock tire sizes...only one size skinny spare.
It doesn't matter what size a spare tire is, as long as it fits over the brakes it'll work.
And it's never recommended to have a space saver temporary spare tire on the front as those tires are used for most of your stopping grip and steering. |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
And i think a 14" wonīt fit if you have disc brakes at the rear end.
Because you cant use 14" normal rims with rear disc brakes, this is because the rear disc has a bigger diameter than the front end discīs. And all hybrids have rear disc brakes son dont bet on a 14" spare wheel
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
Now I have to check mine when I get a chance. I could have sworn my factory donut is on a tiny 14" wheel.
My apologies in advance if I was mistaken. Sent from my Elite_5_5_Octa using Tapatalk
#14 |
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
The spare on my 2009 is a Toyo T125/70D15, which seems like a pretty common size for space-savers.
#15 |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
Well, just to be different!
My factory tyres are 15" and my spacesaver is 16". ![]() It's actually on the car at the moment, I'm having a new tyre fitted but the place who were fitting it damaged the alloy wheel. ![]() Fortunatly the car is not needed until today, when the wheel should be repaired, by them at no cost. At least they admitted to damaging the wheel before I noticed - a slight gouge in one of the spokes. |
#16 |
larger space saver spare
That is very interesting. I noted extra space around the skinny spare...why not have something with the same rolling diameter as the service tires? (And put spare on rear of these front heavy cars...save motion in the differential.)
#17 |
Just out of curiosity, when refitting the "proper" wheel and new tyre, I measured the overall diameter of the 16" spacesaver and the 15" o.e.m. wheel and tyre.
Both are 23.5". So exactly the same rolling diameter for both. |
#18 | |
Concluaion, either full size toyota wheel. Mine's 15" but i dont think its easy to aource locally just one..or try a 15/16" spacesaver maybe that'll fit. Thanks again man for the heada up as at timea i suspected the guy might sell it and was thi kig to myswlf let me just go buy it it should fit. |
| Changing to an MR2 Roadster Steering wheel | MESSIAH | DIY / Maintenance / Service | 2 | 05-03-2015 12:02 PM |
| Black/Grey OEM Leather Steering wheel question | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-14-2011 01:22 AM |
| Wheel Well Question | gwasabi | Cosmetic Modifications (Exterior/Interior) | 3 | 04-15-2009 12:09 PM |
| Question about wheel Offset | monoculusjoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 09-07-2006 03:03 AM |
| Wheel and tire question. | EddyCocaine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 08-31-2006 11:13 AM |
