Old 04-13-2009, 05:43 PM   #1
gwasabi
Drives: 07 Blazing Blue LB
Wheel Well Question
So If I take off the plastic Wheel well cover will that effect the engine in anyway?
My tires keep rubbing after my drop so I thought I'd remove it. I figure on the driver side, I'd worry about water in my CAI and on the passenger side my Pulleys getting wet and slipping. On the other hand I remember there being like a metal plate in front of the engine on the passenger side.
gwasabi is offline   Reply With Quote
Old 04-13-2009, 08:29 PM   #2
Klink10
Klink10's Avatar
I wouldn't. There is alot more stuff that those plastic liners protect. On mine upon removal it exposed the back side of the factory fogs, washer tank etc. Just to much in there for a tire generated sand blaster, rock slinger and whatever to damage. But it is your ride. Good luck.
Old 04-13-2009, 08:35 PM   #3
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
No Don't DO IT!! you can even get the Headlights housings full of water threw the breathers on a rainy day
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 04-15-2009, 12:09 PM   #4
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
yeah you dont want to do that man. I had to cut my wheel wells cuz i was rubbing and just a little cut got water in my CAI and almost water logged my engine =( no bueno at all. I put a cover over my wheel wells after i cut them some more so they wont rub....but even still i get some rubbing =/
Wheel fitment question helladrift Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-02-2008 12:06 AM
Wheel Care Question - Polish coming off? Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-25-2007 05:49 PM
question, do I need my hubs protected by a wheel cover foober Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-28-2006 12:25 PM
20" wheel question mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-25-2006 11:22 PM
