Old 11-30-2008, 10:18 AM   #1
helladrift
Drives: nissan 240sx
Wheel fitment question
Hello, I am a fan of yaris and in the market to get one. but i was curious to know the widest wheel and lowest offset that i could use on a liftbacks? my preference is flushness rather than performance. and yes, the car would be one some type of coilovers.. so any ideas or pics??
helladrift is offline   Reply With Quote
Old 11-30-2008, 03:19 PM   #2
there are members doing 17 x 7 without issues. I believe they run up to 205 width tires.
if you have too much positive offset on the wheel, you can always use 10mm or 15mm spacers to flush it out. Note that on the Yaris, the rear wheels appear to tuck more than the fronts with the same wheels.
Old 11-30-2008, 05:39 PM   #3
helladrift
sweet. thanks for the tip, but still would like to run something a bit wider if possible. does anyone run like 8 width with close to, say ~0 offset? anyone know if there are hub adapters to run 4x114.3 also?
Old 11-30-2008, 10:21 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
My 17x7 38+ offsets were quite flush in the front. You could add a 10mm spacer in the back to even them out.
Old 12-01-2008, 12:50 AM   #5
Contact 03Z33 or Walter on here. They have ran very flushed wheels/tires on their LB's.
Old 12-01-2008, 04:15 AM   #6
nerd_vitZ
Drives: 08 silver streak mica LB
i think +25 front +20 rear is what jeff is running.
nerd_vitZ is offline   Reply With Quote
Old 12-01-2008, 04:04 PM   #7
helladrift
who is jeff..? he's using +25 on an 8?
Old 12-01-2008, 04:14 PM   #8
Jeff is 03Z33
This is what he shows in his garage:
AME Shallen LX Diamond Cut 16x8 +25LO front 16x8 +18SLO rear with 195/45/16 Federal tires
With 195 rubber, he is really stretched!
Old 12-01-2008, 04:24 PM   #9
helladrift
yeaaa ame makes sweet wheels. i like the vip look. i had some wheels that i had off my other car that i wanted to put on the yaris but wrong lug pattern =X they were about the sames sizes as his too. does anyone have any rubbing problems at all. ?
Old 12-01-2008, 07:20 PM   #10
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I have 17x8 with +35 on mine and 205/45/17 tires and it is kinda stretched and rubs on bumps with the DF210s.I have learned to ignore it and drive slow on speed bumps.I wider tire would be torn up in days on my setup,as would my fenders.
Old 12-01-2008, 07:50 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
The Vitz doesn't accommodate anything too radical very well... and remain a good daily driver.
Here's 17x7's and 205/40's on Tien modified suspension. FR, ET42//RR, ET35
It's a nice clean fitment with no worries.
Old 12-01-2008, 08:33 PM   #12
helladrift
for the ppl that are rubbing, did you guys roll your fenders and still having rubbing issues? i think i'd still like to get wheels a bit wider...
Old 12-01-2008, 08:39 PM   #13
kimona
kimona's Avatar
Curious: What is the point in wider wheels when you're basically limited to 205 rubber?
Old 12-01-2008, 08:51 PM   #14
agreed. i dont get it.
crandall runs tenzoR rims that are 17x7 with a 35 offset and 215 tires
he's slammed on tein basics but rubs on bumps or hard corners...
i really dont think an 8" wide rim is a great idea on a yaris....esp w/ a 0 offset.....it looks like poop and does nothing for driveability
Old 12-01-2008, 09:00 PM   #15
helladrift
again, i'm not interested in driveability. i have a car that i track, so i'm just there for look.
and i never said i'm looking to run wider rubber. i'm looking for a better STRETCH.
195/45 is cool for an 8. and i look for lower offset on wheels because i like concave wheels or wheels with lip.
is that a problem?
Old 12-01-2008, 09:23 PM   #16
kimona
kimona's Avatar
is that a problem?
Not a problem, mate. Just some observations from well intentioned yarisworld members... attempting to understand where you want to go with your fitment queries.
Old 12-02-2008, 12:06 AM   #17
helladrift
well thanks for replying and stuff. i think jeff answered most of the questions. thanks.
Wheel fitment? PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-26-2007 12:18 PM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
question, do I need my hubs protected by a wheel cover foober Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-28-2006 12:25 PM
20" wheel question mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-25-2006 11:22 PM
