![]() Drives: 2008 Toyota Yaris Hatch Join Date: Feb 2021
Need illumination wire for aftermarket tach!
I am trying to wire a aftermarket tach and need a 12v illumination wire for the gauge. Where should I go to splice into this? Apparently the dash dimmer switch is an adjustable ground and won't work. And I'd like to not just stab the illumination wire into the keyed hot like most people do
It's a 2008 Yaris hatchback 5 speed 2 door car. Gauge is the standard 4 wire gauge with keyed hot, illumination, ground, and signal. I've got all the wires except illumination
The only Idea I have at this point is a relay that is powered off of the parking light circuit but I'm still not sure where to grab that.
| DIY keyless entry Viper 211HV w/ pics | tmontague | DIY / Maintenance / Service | 24 | 07-06-2025 08:13 AM |
| yaris tachometer installation tutorial if you need <3 | 2010yarisHBbase | General Yaris / Vitz Discussion | 3 | 05-02-2023 12:33 AM |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| 09' tach wire different? [pic] | Taiyaki | Cosmetic Modifications (Exterior/Interior) | 18 | 01-24-2011 01:30 PM |
| Tach Illumination wire | Liu997 | DIY / Maintenance / Service | 6 | 05-29-2009 11:11 AM |
