Old 05-06-2009, 09:31 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
09' tach wire different? [pic]
So I ran into a problem with my tach installation. So i hooked up my orange wire(tach) to the green/blue wire on the far left. But I dont get any reading.
here is a pic of what wire I hooked it up to.
Also I hooked up the rest of the wires to my deck, but seems like the backlight stays on all the time. I hooked up the red(tach) to red(deck), white(tach) to yellow (deck), and well the black went to the ground. Did I mix up the wires?
Old 05-06-2009, 09:46 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I believe the tach signal wire is only green/blue on 07/08.
the circled wire is where mine is, and I believe it would be the same on yours (just a different color), since that connector is industry standard.
Old 05-06-2009, 10:11 PM   #3
Taiyaki
アキバ製
Taiyaki's Avatar
I hooked it up to that wire and same thing. no reading. I wonder if I am tapping from the right place?
here is where I am.
and here the wire
Anyone know what to do?
Old 05-06-2009, 10:14 PM   #4
AlexNet0
AlexNet0's Avatar
You are in the right place.
On the tach the red is 12v power, the white is for the dimmer switch (illumination) wire. that wire on the OBDII port is the correct one to the best of my knowledge.
where did you ground to? If you can post a pic of the electrical connections as well
Old 05-06-2009, 10:23 PM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
I connected it to the deck ground, I thought it was fine since the back light and everything else works, just no reading. Should I ground it to the car?
Old 05-06-2009, 11:59 PM   #6
Taiyaki
アキバ製
Taiyaki's Avatar
I also grounded it to the body, and still no reading. any know whats wrong?
Old 05-07-2009, 01:32 AM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
You may have fried it by hooking the tach sensor to the wrong wire.
Old 05-07-2009, 01:40 AM   #8
Taiyaki
アキバ製
Taiyaki's Avatar
Can someone confirm this? if i need to get a new one or maybe not.
Old 05-07-2009, 02:16 AM   #9
I thought 07 was green, 08 was pink, and don't know 09
Old 05-07-2009, 02:25 AM   #10
Taiyaki
アキバ製
Taiyaki's Avatar
yah supposely 09 is the light brown wire that is all the way to the left separated from the rest. But when i hooked it up still didnt get any reading.
I had a problem like this with my Celica, and I pulled the wire threw the firewall and put the wire near where the tach fuse was. I want to give it a try. I looked in the manual but cant find where the tach fuse is. can some one point it out for me?
Old 05-07-2009, 05:38 AM   #11
Taiyaki
アキバ製
Taiyaki's Avatar
nevermind problem solved
Old 05-07-2009, 06:16 AM   #12
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
what was the problem? (I plan on adding a tach soon, myself)
Old 05-07-2009, 06:27 AM   #13
Taiyaki
アキバ製
Taiyaki's Avatar
well my tach was straight from Japan, so i guess normally the white wire that would go to the consistant was for the tach wire and yeah. I would never have known that if battleversiontc didnt help me.
Old 05-07-2009, 05:08 PM   #14
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
so which is the color for tach line? (car side) Glad you got it to work, makes me confident to do mine this weekend.
Old 05-07-2009, 05:23 PM   #15
Taiyaki
アキバ製
Taiyaki's Avatar
the white wire went to the tach
Old 05-07-2009, 10:58 PM   #16
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
on 09 its the lt brown wire closet to the hood latch on the obd2 diagostic port post #3 second picture is the tach wire for 09, but for all the years the tach wire for wiring a aftermarket tach on the wire should be in the same location just different color and if toyota ever changed it they need a new adapter in order to run diagnostics
tach connection on obd2 plug
07/08 lt greenish blue wire
09 lt brown wire
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 01-24-2011, 02:20 PM   #17
markkona
Drives: toyota Yaris sedan aka Belta
Hi has anyone installed an aftermarket tach on a toyota belta japan import please? I would like to know where to fit the tach wire to the obd port if possible. cheers Mark.
markkona is offline   Reply With Quote
Old 01-24-2011, 02:29 PM   #18
^ Read the post before yours. It's most likely that the position stays the same even if the wire color changes.
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 09:53 PM
Tach Illumination wire Liu997 DIY / Maintenance / Service 6 05-29-2009 12:11 PM
Tach ECU wire, auto Liu997 DIY / Maintenance / Service 8 05-06-2009 02:44 PM
Dimmer Wire for Tach mrrock DIY / Maintenance / Service 7 11-29-2006 08:18 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 02:05 PM
