Old 05-26-2007, 11:46 PM   #1
ttufrosty
5w-20 Oil
Usually I run Mobil 1 5w-30 in my Yaris (3dr LB, Manual) but for this trip I am taking right now I wanted to try 5w-20 to see what a difference it would make in mileage. Normally I get about 38-40 mpg on the 5w-30 to and from work all highway miles, no A/c, just me.
Yesterday on the first leg of the trip from Dallas to Kansas City, fullly load, 3 passengers, and A/C on all the way with the 5w-20 (Mobil 1) I averaged 39 mpg. Based on the initial part of this trip it seems the 5w-20 does improve the gas mileage. Also consider I was driving between 70 and 80 the entire way.
Take it as you will, I will update further as the trip goes on.
ttufrosty is offline   Reply With Quote
Old 05-27-2007, 01:20 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Toyota TSB says 5w-20 is better for gas milage and is A-ok for you in the South.... us northerners can run 0w-20
I noticed a differance in MPG when I went to synthetic, and a little better when I went to 0w-20
Old 05-27-2007, 11:43 AM   #3
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
What about in cold or hot weather, I really don't know much of a difference in oil, but in PA the summers are HOT and the winters are COLD. I was told 5w-30 is what I should stick with, but if I can get better milage with a different oil, I'd try it out but I'd be worried about my weather conditions.
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 05-27-2007, 11:55 AM   #4
Black Yaris
der Zeck
then just stick with 5w-20 per the Toyota TSB, it is the safe way to go. 5w-20 is one of the most common viscosity oils for many modern cars
Old 05-27-2007, 06:33 PM   #5
ttufrosty
The summers in Texas are obviously Hot, but since I am a teacher I dont do a lot of driving in the summer, so I am not too worried about the high temps. On the drive so far the temps have been in the 60's to 80's, so perfect driving weather.
Old 05-28-2007, 12:17 AM   #6
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
5W-20 TSB
Just In case someone would like to read it.
blacksan is offline   Reply With Quote
Old 05-28-2007, 06:44 AM   #7
Nigal
Nigal's Avatar
So would the 0w-20 be OK for Ohio summers?
Old 05-28-2007, 06:30 PM   #8
jlift
Drives: 2007 Yaris Hatch
Yes. My take on all this, after extensive reading, is the the 0-20W FULL synthetic (NOT Mobil 1, Castrol Syntec, but Amsoil) will be fine for your Yaris if you do not have harsh winters where you live (snow). I live in So. California, so I just ordered the Amsoil 0-20W FULL synthetic (it's a relatively new product and Amsoil states it can be used in your car...go to amsoil.com). The Mobil 1, Castrol Syntec, are NOT full synthetic but apparently come from a variation of mineral oil. Amsoil is the way to go, I think.
jlift is offline   Reply With Quote
Old 05-28-2007, 09:25 PM   #9
Nigal
Nigal's Avatar
Thanks. I'm putting about 1,000 a week on my S I'm changing the oil about every five weeks. The price on their web site was almost $10 a quart. I think I may go broke at the rate I'm going. :(
Old 05-29-2007, 12:47 AM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I don't think AMS is any better than Mobil 1.
Old 05-29-2007, 02:50 AM   #11
Black Yaris
der Zeck
I am running 0w-20 mobile 1... buy the oil from walmart, it is the cheepest place in town...
Old 05-29-2007, 07:09 AM   #12
Nigal
Nigal's Avatar
I'm normally the typical lazy American who ducks into the quicklube place on lunch to get my oil change but I guess if I buy the good stuff by the case and do it myself I'll get better oil, better mpg and still save money.
How much of a jump in mpg did you notice?
Old 06-23-2007, 08:27 AM   #13
curik
Drives: 06 yaris AT
is Amsoil 0w-20 fine for me who lives at a place near the equator? Like 25-35 deg C all year round. Thanks!
curik is offline   Reply With Quote
Old 06-23-2007, 11:17 AM   #14
blacksan
blacksan's Avatar
I personally would stick with the 5W-20. The temperatures in your area warm enough that they would not warrant 0W-20 in my opinion and might not protect as well as 5W-20 under heavy loads and higher engine temperatures.
Old 06-23-2007, 09:26 PM   #15
curik
Drives: 06 yaris AT
Thanks blacksan, so 5w-20 it is. If I cannot get Amsoil is there any other brands? Like Mobil 1? It is fully synthetic right?
Old 06-23-2007, 09:43 PM   #16
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
it should be known, 5W-20 and 0W-20 have exactly the same properties in a warm engine. Only difference is when the engine is still cold, the 0W-20 will be a little more fluid. 5W-20 or 0W20 in very hot climate would be OK only if the engine is usually kept at low rpms.
hystria is offline   Reply With Quote
Old 06-23-2007, 09:45 PM   #17
blacksan
blacksan's Avatar
The only full syn Mobil 1 is the extended performance. I grew up on a farm and we used the Amsoil in all our heavy equipment and I really like it!!! If you can't order it (Amsoil) I would go with the Mobil 1 extended over regular Mobil 1.
BTW, I use Hastings filters with my Amsoil as there are very high quality.
Old 06-24-2007, 12:26 AM   #18
curik
Drives: 06 yaris AT
Maybe that's why the Toyota Genuine Motor Oil here is 20w-50. Thats right! I am still on 20w-50!! So will it be OK to use 5w-20? I'm driving it normally with occasional redline.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 04:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
