Old 11-13-2009, 06:04 PM   #1
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
About spring rates...
Howdy folks,
First things first, I'm a grade-a n00b so go easy on me please.
I've been looking at lowering springs/shocks/struts/coilovers/whatever and I've got a question about how to interpret the different ways that spring rates are listed.
All of my examples come from the Micro Image website since it's the easiest to get to.
AOE TigerTec springs: 1.75" drop - 4k front, 3k rear spring rate
Tanabe DF210 springs: 1.6"/1.8" drop - 3.0 front, 2.2 rear spring rate
Tanabe NF210 springs: 1.1"/1.3" drop - 2.5 front, 2.2 rear spring rate
Progress Lowering springs: 1.7"/1,8" drop - 110lbs front, 130lbs rear spring rate
How do I compare 4k/3k to 3.0/2.2 to 110lbs/130lbs of spring rate?
Do higher numbers = a stiffer ride? If so, how does this affect handling?
Thanks in advance for answers and knowledge,
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 11-13-2009, 06:08 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The Progress ones are softer that the others, lemme see if i can find the conversion. And yes, the higher the rates the stiffer. And the higher rates make handling better, in general. But the higher the rates the worse the ride comfort.
http://www.onlineconversion.com/foru...1110951659.htm Here is a simple one.
"Springs are rated in pounds/inch in the U.S., and Newtons/millimeter elsewhere. I have not seen kilograms/millimeter before, but the conversion will be easy enough.
1 pound = 0.45359237 kilogram
1 inch = 25.4 millimeter
0.45359237/25.4 = 0.0178579673228346
The conversion factor is 0.0178579673228346
So, to convert lb/in to kg/mm you multiply by 0.0179 and to convert kg/mm to lb/in you divide by 0.0179 "
Colin Chapman disciple
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 01:33 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 05:24 PM
Spring rates IllusionX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 04:05 PM
