Old 05-20-2010, 02:51 PM   #1
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
What is that connector for? (in the door)
There is a white plastic connector in my doors that I noticed when I was putting in new speakers. I would say it is about 8 inches above the connector for the speakers. I would guess it is for power locks, but could also be for power mirrors or windows possibly, all of which are options I do not have.
If it is for power locks, could it possibly be as easy as buying a switch and wiring into the connector to add power locks to my current setup...
So anyway, does anyone know what that connector is for?
Old 05-20-2010, 03:51 PM   #2
That would be connector G1 (power window master switch) or G4 (power window regulator motor). G5 is for the power door lock, and it is located by the door latch (for the actuator).
The main body ECU (which is located inside of the under dash fuse panel) controls the door locks, so you just have to add the actuators and switches to have power locks.
Old 05-20-2010, 05:03 PM   #3
kac
kac's Avatar
Thanks CTScott. I don't plan on doing anything with it. I knew it was for some option that I don't have since it's not hooked up, so I was just wondering. I appreciate your insight.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
