Old 09-15-2009, 01:12 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Weird thing..my left wheel sits in more than the right
I installed 12mm hub spacers, measured both to be 12mm, thing is after i was all done i noticed that the left wheel sits in more than the right. Guess it wasnt noticeable till the wheels (15 steelies) were spaced out. I made sure that both sides fully bolted closed no gaps or anything. The only thing i have left to test is switching the rear wheels around to see maybe its the wheels offset (iono). So i cant attribute it to the spacers because they are both the same size...
Check out my Build thread:
Old 09-15-2009, 01:18 AM   #2
Same tire pressure on all corners?
Old 09-15-2009, 01:19 AM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
PM Tamago, he'll be all over this one......
Old 09-15-2009, 01:22 AM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have exactly the same problem. Subscribed.
Old 09-15-2009, 01:33 AM   #5
ezhacker1
ezhacker1's Avatar
Yup i checked that, ill take another look tomorrow. I installed them saturday. If i had to guess the difference in offset, id say probably ~10mm....
Whats your pre/post spacer offset? What do you think the difference in left and right for you?
Old 09-15-2009, 01:35 AM   #6
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
If the problem isn't solved, i may be coming to SFSU to drop off my visitor enrollment paper, so i can come by your place and we can swap wheels to see with my 17s if you are having problems still....?
Old 09-15-2009, 01:38 AM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have 205/50R15 +38 offset. I would say that the right wheel sticks out by about 3mm more than the left and it rubs like hell when there's passengers in the back.
Old 09-15-2009, 01:43 AM   #8
ezhacker1
ezhacker1's Avatar
Cool, id love to see some (actual wheels) on my car than steelies. Plus there would be someone else to see what i mean about the differences in offset.
Maybe 10mm was a bit much, i dont know how to really measure it, there arent really any right angles or anything. But definitely is visible difference.
Old 09-15-2009, 05:45 AM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
Acceptable manufacturing tolerances. Pretty normal on our cars to have right to left differences. We covered this issue in a few threads way back when.
Old 09-15-2009, 05:58 AM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I'm hoping to get my hands on a fender roller soon, or else I'll have to remove the spacer which I really don't want to do...
or perhaps I could get the right-side spacer shaved by a few mm?
Old 09-15-2009, 06:49 AM   #11
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Funny you should say that , i took mine into Toyota ,with the same
thing , and that was there comment .
But they did sort of fix it , by pulling the right rear guard out .
Take your rear wheels off run a tapemeasure from the gaurd lip
to the back of the wheel well . you will find your 3-5mm differance between sides .
Old 09-15-2009, 07:44 AM   #12
silver_echo
ekodrvr
silver_echo's Avatar
so here is an idea... for people that are getting ready to try purchasing the spacers, why not have person measure out before and then have the set include perhaps one 12 and one 9 spacer? just an idea, i don't know about the manufacturing requirements, but it is a thought... if this cannot work, just let me know and i will remove/edit this post...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 09-15-2009, 09:45 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
all yarii are crooked
Old 09-15-2009, 02:45 PM   #14
ezhacker1
ezhacker1's Avatar
wow.. ill measure the difference with wheels off, then go from there. But just plain..wow
Old 09-15-2009, 02:51 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
penguin garage (with the help of TK-421) discovered this when we sent out the first few sets of spacers.. if you'd ordered PG spacers instead of knock-offs they would have come with camber shims to prevent rubbing
Old 09-15-2009, 04:26 PM   #16
ezhacker1
ezhacker1's Avatar
my problem isnt rubbing im only on nf210s problem is one is just sits in more than other. Once i get home ill measure the difference to see if i need to purchase another spacer to add on.
Old 09-15-2009, 04:32 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
just live with it. the car's crooked to begin with lol
Old 09-15-2009, 04:52 PM   #18
ezhacker1
ezhacker1's Avatar
i guess i didnt notice it being crooked before
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Seat cushion for thigh, center armrest left armrest BMGYaris Cosmetic Modifications (Exterior/Interior) 2 07-03-2009 11:51 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
