Old 01-21-2012, 01:48 AM   #1
spookybathtub
Drives: 2007 Yaris HB
Mysterious extra wiring harness in door
Today I began the sound deadening project in my 3-door hatchback. When I removed the door panels, I noticed an extra wiring harness at the top near the front. Does anybody know what this is for? It has 5 wires going to it (white, white, black, purple, light blue). It's in a good position to use for a tweeter, but I have no idea where it leads to.
spookybathtub is offline   Reply With Quote
Old 01-21-2012, 07:53 AM   #2
That's the power mirror wiring.
Old 01-22-2012, 01:05 PM   #3
spookybathtub
Aha. Thanks.
Another question — there is some foam in here, I'm wondering what it's for. There is a chunk of rigid styrofoam bolted to the outer door skin, about 1.5" thick. I've heard it's related to the window, but there's about 1/4" clearance so the window never touches it.
Also - attached to the plastic door panel, there are 2 pieces of high density molded foam that fit into the holes in the inner door skin. I'm going to be covering the door, including those holes, with MLV, so this foam will be in the way. Are these just there to stiffen the door? Has anyone removed them and had any problems with the door being flimsy?
Old 01-22-2012, 01:39 PM   #4
I believe that they are actually part of the crash system for the car. The do provide some stiffening, but not enough where you would notice if they were gone.
Old 01-22-2012, 01:57 PM   #5
spookybathtub
Hmm... So it would be more dangerous to remove them then?
Old 01-22-2012, 05:18 PM   #6
Theoretically yes. I believe that the foam is there to help during side impact.
Old 01-22-2012, 05:33 PM   #7
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
its for if you wanted to float your car across a flooded road
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Aftermarket wiring harness help yuriyaris615 In Car Entertainment + Electronics (audio / video / alarm) 1 05-18-2010 10:29 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 09:18 AM
