Old 12-09-2011, 02:50 PM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Codes pulled
Since the dealership is absolutly no help so here i am lol. My mecanic plugged a dianogstic computer into my car, bc I wanted 2 know why my airbag lights is on. So getting to piont i geuss here's the codes he pulled:
V1801
V1811
what do they mean? how are can they be reset? Also came up something called a "squib circut" what's that?
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 12-09-2011, 02:59 PM   #2
barryware
Make: Toyota
Code: B1811
Definition: Open in D squib (Dual stage - 2nd step) circuit
Make: Toyota
Code: B1801
Definition: Open in D squib circuit
A squib is the actual part that explodes to inflate the airbags. There are also squibs that lock up the seat belts. the definition makes me think that there is a wire open in the ignite circuit. I don't know which squib would be "D".. You will not be able to clear the code until the problem causing the code has been repaired.
barryware is offline   Reply With Quote
Old 12-09-2011, 03:12 PM   #3
Qmobile
Qmobile's Avatar
ok how do i do that? i tend to think D would start for driver but idk
Old 12-09-2011, 03:20 PM   #4
The 1801 and 1811 DTCs point to the spiral cable (AKA clockspring) having a snapped wire within it. You can pull the airbag and check continuity between the two pins of the black airbag connector and pins 7 and 8 (yellow with green and yellow with red wires) of the spiral cable connector at the bottom of the steering column.
Old 12-09-2011, 03:47 PM   #5
A-Dingo-Ate-My-Baby
Drives: yaris
diagnotics for tacoma [same as Yaris in general sense of what to look for]
http://www.ncttora.com/fsm/2003/Repa...s/cib01011.pdf
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 03-13-2012, 04:58 PM   #6
Qmobile
Qmobile's Avatar
ok is there ANYWAY possible that this could be linked to my horn not workin now? :(
Old 03-13-2012, 05:09 PM   #7
The horn not working may be another symptom of a bad spiral cable.
Old 03-13-2012, 09:15 PM   #8
Qmobile
Qmobile's Avatar
damn was afraid of that
check engine light - reading codes? delbo21 DIY / Maintenance / Service 3 09-02-2011 05:48 AM
How to Reach Trouble Codes without Scanner? tahir44 General Yaris / Vitz Discussion 5 04-19-2011 09:55 AM
CEL= P0300-P0304 CODES........ ROCKLAND TOYOTA DIY / Maintenance / Service 3 04-11-2011 06:18 PM
P2420 and P0441 codes jkonrath DIY / Maintenance / Service 3 09-05-2010 09:33 PM
Fault Codes P0441, 442, 446 soloecho2 DIY / Maintenance / Service 1 04-25-2010 06:21 PM
