Old 04-09-2011, 02:04 PM   #1
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
CEL= P0300-P0304 CODES........
just took the techstream off the car and found i had the 4 following codes:
P0300
P0301
P0302
P0303
P0304
we cleared codes and so far nothing has come back. i found this on youtube and wondered WHO'S CAR IS THIS????
http://www.youtube.com/watch?v=KjZR7...layer_embedded
i had almost no gas in car when this happened so i filled up with premium and lets see what happens.....
Old 04-09-2011, 04:44 PM   #2
severous01
looks like a random misfire code, and miss on cylinders 1-4
if you were out of gas that would throw a misfire code. also, if you filled up and it hasnt come back then you should be good.
Old 04-11-2011, 07:27 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
wasn't out of gas at all! first time was on highway between 75-80 and car just shut down in limp mode for about 30 seconds before allowimg me pedal use again with no CEl. second time came after a 4 day no use and after first turning ignition car refused to stay running and threw this code.....
Old 04-11-2011, 06:18 PM   #4
severous01
bad gas? EMF disrupted coils? if its not happenin y worry?
P2420 and P0441 codes jkonrath DIY / Maintenance / Service 3 09-05-2010 09:33 PM
Fault Codes P0441, 442, 446 soloecho2 DIY / Maintenance / Service 1 04-25-2010 06:21 PM
