Old 09-15-2012, 03:05 AM   #1
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
LED Color Change Problems w Drivers Door
OK this was bound to happen. In the process of me learning how to solder on my car's circuit boards and changing the LED color to white, I ran into a snafu. I thought I was doing good changing out the drivers door power panel LED until after I plugged the harness back in and the drivers window rolled down and wouldn't roll back up. The rest of the windows in the car rolled up and down and the AUTO light was now white, but the drivers would not go up. Then after awhile with messin with it, I realized there were little switches under the bigger switches and realized that if they aren't lined up just right, the windows won't work. At some point, After finally getting the drivers window to roll back up, the AUTO light stopped working and now the 3 other windows wont move. Did I just blow a fuse or something or did I really mess up the soldering job on this little circuit board on the door??
jeeper5usa is offline   Reply With Quote
Old 09-15-2012, 08:31 AM   #2
The 7.5A PANEL1 fuse under the bottom of the dash drives the power window switch illumination.
The 30A POWER fusible link on the face of the under dash fuse panel drives the power windows.
Hopefully you didn't mess up the switch as they are hard to find, even used, for under $100.
Old 09-15-2012, 12:32 PM   #3
jeeper5usa
jeeper5usa's Avatar
Sorry, In trying to put back the switch the window lock button was pressed Although with my crappy soldering job, the LED came off so is no longer working. I guess Ill wait for help when I find someone to help me with my instrument cluster to help me with the switch. Thanks for the answer, your the man!
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 02:24 AM
Where do I connect the LED door sills Sedan rene0023 Cosmetic Modifications (Exterior/Interior) 2 12-18-2011 04:03 PM
LED Door mirror cover -Thailand Violin Cosmetic Modifications (Exterior/Interior) 115 07-19-2007 08:50 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 10:18 AM
