Old 06-02-2014, 03:34 AM   #1
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
RATTLING NOISE EXHAUST PIPE/BACK OF ENGINE
HELP!
I've read through the forums related to this issue and still no success. I have a weird rattling noise that comes once done within the following:
1.) driving the vehicle more than at least 15 minutes
2.) the car is in drive and the foot on the brake pedal
The rattling goes away when in neutral, and it isn't there in reverse as well.
The sound is very strong behind the engine bay and the noise goes with shaking the engine back and forth by hand. My friend and I noticed that the noise also went away when a flat head screw driver is wedged between the mid-pipe connected to the up-pipe (headers) towards the engine. I also pushed up (braced) the mid-pipe towards the bottom of the car and the engine goes away too.
My friend strongly feels and convinced that my gasket that connects the two pipes is most likely bad and that there is an exhaust leak possibly. but the car does not sound like it has one.
I drive a 2009 3dr. hatchback, aftermarket exhaust, over 100,000 miles.
ps. I also tried the zip-tie of that cable method and it is still there. Plus checked most of the head shield through out the exhaust pipes and still nothing.
joeljcruz86 is offline   Reply With Quote
engine bay, exhaust, noise while moving, noises, rattling
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 01:34 PM
anyone use Dynamat/ Be Quiet to deaden exhaust noise? Galavoxx Performance Modifications 9 11-29-2006 05:28 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
