Old 06-07-2007, 12:14 AM   #1
thomasward00
thomasward00's Avatar
Drives: 2007 Yaris Sedan
excessive valve and or engine noise?
I have a sedan automatic, and when my car idles in and out of park, I hear excessive valve noise, does anyone else have this issue. My car has 3300 miles on it and i'm not comfortable with this from a new car. The dealership mechanic told me that cheap cars just make more noise... I guess i'll call toyota tomorow and complain.
thomasward00 is offline   Reply With Quote
Old 06-07-2007, 12:29 AM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
have you checked the oil level lately? Have you recently changed fuel brand, or station where you purchase?
blacksan is offline   Reply With Quote
Old 06-07-2007, 01:34 AM   #3
thomasward00
Yes i've kept an eye on my oil level and its been fine, I only have only filled up at Exxon, I don't use cheap gas.
Old 06-07-2007, 12:34 PM   #4
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
the valve train noise you are hearing is normal, and means that your engine is functioning properly. start worrying if mpg's drop, or large chuncks of metal are found in the engine oil.
otherwise, everything is a-ok. I've owned 3 toyotas. A '87 pickup, a '94 corrolla, and my '07 yaris. The first two had over 200,000 miles, and made similar clicking noises...it is a toyota engine attribute that takes some getting used to.
fu_im_from_texas is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
