![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
How long did your clutch last?
My 08 sedan just turned 180K kilometers, no problems with the clutch at this point,was wondering how long before i can expect to replace it, and whats a ball park figure of cost.
Thanks
Have Yaris will travel.. |
It is a couple hours to drop the transmission to change the clutch and put it back. So you are looking at 500+$ already.
![]() ![]() ![]() Drives: Toyota Yaris 2009; 1.0 3 Cil. Join Date: Oct 2010
Got 1KR-FE engine (1.0) Yaris 2009 build in france.
Got 81k's on it... clutch still going strong... If my clutch is going to slip once in a while I'm going to change it.
Speedbumps suck...!
Mine had 116k miles when I replaced it back in April. Still had life left but it was definitely slipping.
Sent from my iPod touch using Tapatalk |
A clutch in my experience will last forever if you dont abuse it.
But then again, those were in engines that were throttle by cable, not throttle by electrical wire. The throttle response in my 09 with auto makes me wonder if its possible anymore...
#6 | |
A clutch should last a long time, provided only one person drives your car.
My car has been used for as many as three people at some point and the clutch wears down much faster in those cases. I've already gone through 3 clutch kits on my Yaris.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
2011 3-door, four years, 114,000 miles, and no problems. I test it occasionally by short shifting from first to fourth (gently). Plus my 35mile (one way) daily commute includes two fairly long inclines each way, in fifth gear. Still no signs of slipping. However, I can tell it is worn significantly since the pedal is somewhat stiffer than when I first got the car.
| Toyota yaris 2002 - Hard clutch | abhinav_kr | DIY / Maintenance / Service | 10 | 06-29-2016 07:08 AM |
| '07 Yaris Clutch replacement | dinop | DIY / Maintenance / Service | 12 | 04-22-2013 04:47 AM |
| Clutch question. | Black_griffin6 | Performance Modifications | 6 | 04-04-2013 04:30 PM |
| Clutch pedal assembly interference with foot | Connoisseur_of_fine_cars | General Yaris / Vitz Discussion | 4 | 09-23-2011 10:57 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
