Old 11-19-2014, 07:50 PM   #1
Yar Is Thy Name
Drives: 2007 Toyota Yaris HB
OCV or VVTI Solenoid.. Drive Belt Change
2007 Yaris hatchback. 60K miles.
I changed out the drive belt on my wife's Yaris and used a rounded metal pry-bar between the engine and alternator and looks like I have joined the ranks of the CEL code P0010 peeps.
I reviewed a few DIY post on the belt replacement before I got started, but still I messed up.
I don't recall hitting the OCV located near the topside/engine-side of the alternator, so I am wondering if there is another solenoid or sensor located between the alternator and block that I may have hit and damaged?
After reading several post on the subject it seems that the camshaft timing oil control valve (OCV) part # 15330-21011 is usually the issue. I haven't removed and visually inspected it yet.
Where is the VVTI sensor located?
Anyone used OEM sensor or solenoid replacements from E-bay?
All replies appreciated
Yar Is Thy Name is offline   Reply With Quote
Drive Belt jiamanuel Middle East 12 11-10-2011 09:30 AM
Need help replacing acessory drive belt!!! stevebo DIY / Maintenance / Service 13 04-07-2011 02:57 PM
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
service life of accessory drive belt? stevebo DIY / Maintenance / Service 5 05-10-2010 01:29 AM
Drive belt question toyo DIY / Maintenance / Service 4 02-22-2010 07:42 PM
