Old 02-17-2015, 05:36 PM   #1
xorrbit
Drives: 2007 Yaris 5-door Liftback
Cause of growling noise when accelerating?
I have a 2007 1NZFE ATM 5D Yaris with 125,000ish km on it. Awhile back I noticed it started "growling" whenever I was accelerating. This only happens while in gear (does not happen when in neutral and revving) and only when you accelerate. It is not noticeable when you're coasting or cruising at speed.
From searching the forums it sounds like maybe I should check an exhaust manifold gasket (either tighten the bolts or replace the gasket altogether) or just check the exhaust for a hole/leak. Does anyone know which gasket is the one that normally goes? I'm thinking #11 in this diagram: http://www.toyotaonlineparts.com/aut...-manifold-scat
I'm also wondering if anyone has any other suggestions or knows what it might be - I'm going to be doing an oil change this weekend and plan to spend some extra time trying to figure out why it is doing this. Note it has been doing this for quite awhile (> 6 months) and doesn't appear to be problematic per se, just annoying :).
Thanks!
xorrbit is offline   Reply With Quote
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 12:20 AM
Whirring Noise when accelerating RatedRVD DIY / Maintenance / Service 11 06-06-2012 12:07 PM
drivetrain is making funny noise while accelerating whoknows89 DIY / Maintenance / Service 0 02-09-2012 04:28 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
