Old 05-20-2012, 08:26 AM   #1
RatedRVD
Drives: Yaris Mk2
Whirring Noise when accelerating
Hello
I have 2008 Yaris 1.0
Its done 10k miles.
I've noticed today that when i accelerate, i can hear a whirring noise coming from the front of the car.
If i put the clutch down, the noise stops, until i take my foot off the clutch again.
If i have the car in neutral and rev the engine i can hear the sounds
I've had a mechanic have a look and he can't see anything wrong.
So any ideas?.
Thanks
EDIT: It sounds more like a whistle blowing,
RatedRVD is offline   Reply With Quote
Old 05-21-2012, 02:19 AM   #2
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Have the water pump checked for leaks. It kind of makes a hissing noise and is known to be an issue with the 1.0 engine.
The blue one
Old 05-21-2012, 02:56 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by RatedRVD View Post
Hello
Its done 10k miles.
So any ideas?.
Thanks
It could possibly be the throw out bearing making noise when it's spinning freely, but when you push down on the clutch pedal, that moves a forked lever which causes the throwout bearing to press against the clutch arms and it stops making noise.
Old 05-21-2012, 10:02 AM   #4
RatedRVD
Drives: Yaris Mk2
Hi
It sounds more like a whistle blowing, and it seems to be coming from the passenger side of the bonnet.
I havn't check the water pump- i dont know what to look for
I went to another mechanic and he said its not the throw out bearing, or clutch related and its just normal Yaris noise.
I rang Toyota and they said they can look at it if i pay a "investigation fee" of £90/$142 so they can identify it.
Old 05-27-2012, 11:32 AM   #5
RatedRVD
Drives: Yaris Mk2
Took it to different mechanics, he said the Water pump has been leaking in the past, but isn't now.
It sounds like this:
http://www.youtube.com/watch?v=YsJy1IAqNn0
*not my video - not a yaris either
its the whistle like sound.
Old 05-27-2012, 12:51 PM   #6
MadMax
MadMax's Avatar
You sure it's not just the engine?!?
Old 05-28-2012, 11:55 AM   #7
RatedRVD
Drives: Yaris Mk2
New Mechanic says its the Alternator whistling.
Its fine, but its just making a louder noise then normal.
£245 to get it replaced.
Old 05-28-2012, 02:24 PM   #8
2o6
Drives: 2007 Liftback
Your vehicle has grown a turbocharger.
2o6 is offline   Reply With Quote
Old 05-28-2012, 03:47 PM   #9
Chuck G
Drives: 2010 Yaris Sedan
Old 05-28-2012, 05:33 PM   #10
RatedRVD
Drives: Yaris Mk2
Am i right in assuming most Yaris Alternators shouldn't go after 10k miles?
Old 05-28-2012, 07:38 PM   #11
braytonia
Drives: Nothing Yet...
Did you pop the hood and physically look in the engine bay? You could have a hidden Supper Charger!! That what it sounds like to me... :P
braytonia is offline   Reply With Quote
Old 06-06-2012, 12:07 PM   #12
RatedRVD
Drives: Yaris Mk2
Noise has been fixed.
It was the water pump after all.
Thanks for the help
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
drivetrain is making funny noise while accelerating whoknows89 DIY / Maintenance / Service 0 02-09-2012 04:28 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Whirring Noise from Rear Left side Betrivent DIY / Maintenance / Service 4 12-15-2010 07:15 PM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
