neilc
Drives: Yaris 1.33 TR VVT-I Join Date: Dec 2015
Low idle speed after battery disconnected
Hi all,
I've had my 2009 Yaris VVTi from new and have never had any issues with it, until it went in for a recall to have the airbag replaced and the battery was disconnected. Now, on a cold start the idle speed is much lower than it used to be and the engine almost stalls. The idle speed on cold start used to be about 1000rpm but now it fluctuates between 500 and 800 rpm. Touching the accelerator to increase the revs to 1000rpm stops it stalling and after driving for a few minutes the idle speed is fine and the car runs as before. Took it back to the dealer who kept the car overnight and said they saw the cold start issue but there are no faults showing on the ecu so there's nothing they can do! Have seen a few posts about this type of problem clearing after a couple of days, or after a long drive. But it's been 7 days now and I had a 200 mile round trip one day last week but I still get the problem on a cold start. Any suggestions? Thanks. |
If it was the ECU re-learning due to battery disconnect it would affect all starts, not just cold start. Not sure where to direct you other than maybe cleaning the MAF sensor on the air intake.
^ what he said plus look into vacuum leaks
Clean the throttle body and problem solved keep in mind it's by wire so key forward have someone push gas pedal to open throttle to clean do not use ur fingers to open it...this problem is common do to reset caused by no power mainly on cars with higher milage.
Sent from my Samsung Galaxy S6 |
| Tags |
| cold start, idle problem |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Low RPM when Idle | Betrivent | DIY / Maintenance / Service | 12 | 03-03-2013 06:55 PM |
| Low rpms with a new battery | jaimico | DIY / Maintenance / Service | 8 | 04-08-2010 06:17 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
