Old 06-05-2016, 02:20 AM   #1
Faheem Hussain
Drives: Toyota Vitz 2008
Spark Plugs
What is the best spark plug for Toyota Vitz 2008?
Faheem Hussain is offline   Reply With Quote
Old 06-05-2016, 05:50 AM   #2
jcboy
Drives: Sedan 07
re your question, best is a matter of category.
financial aspect: OEM is best
other aspects: i have no idea, though i've tried Bosch platinum before, and it performed really well over OEM Honda plugs and costing only about US$1 more each ($3 vs. $2)--but that can also be because it's for a relatively older engine.
Old 06-05-2016, 05:11 PM   #3
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
bosh platinum is a bad idea.
OEM is a good idea.
I'm also partial to denso TT spark plugs.
jack black is offline   Reply With Quote
Old 06-05-2016, 08:45 PM   #4
jcboy
Drives: Sedan 07
OEM is a good idea.
OUCH. ok i take that back. well in my defense i did replace the plugs every 10k kms, as they were nonOEM and i wanted to play it safe. So yes, OEM seems best still.
Old 06-07-2016, 10:52 PM   #5
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Every 10,000k??? They're good for about 160,000 km
Old 06-09-2016, 12:21 PM   #6
jcboy
Drives: Sedan 07
haha yeah, i didnt know any better then, was in college, google wasn't as readily available as it is now...in short, i thought plugs were like oil changes. (every 10k kms)
Old 06-05-2016, 05:20 PM   #7
joell
joell's Avatar
Drives: 2013 Hatchback
Denso and NGK are normaly found as factory installed in our engines.
joell is offline   Reply With Quote
Old 06-05-2016, 05:49 PM   #8
Tinkerman
Drives: Yaris 5 speed
NGK iridium is the best.
Tinkerman is offline   Reply With Quote
Old 06-06-2016, 08:09 AM   #9
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I use NGK Iridium
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 06-06-2016, 07:40 PM   #10
Tinkerman
I used NGK for all 5 but one the F150 can only do OEM Motorcraft, what a blow.
Old 06-08-2016, 11:04 AM   #11
tarkus
tarkus's Avatar
And why does being OEM make them better? I tend to think the opposite.
Old 06-08-2016, 04:07 PM   #12
Tinkerman
You need to re-thinking.
Old 06-08-2016, 04:11 PM   #13
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I tend to agree. I would only not go OEM if they weren't readily available and you needed them immediately.
Sent from m-o-b-i-l-e
Old 06-09-2016, 12:35 AM   #14
tarkus
tarkus's Avatar
Seriously dude?
Old 06-09-2016, 12:45 PM   #15
Rigaud
Drives: 2009 Yaris
Seriously dude?
Yup I agree with re-thinking!!!
Old 06-08-2016, 08:35 PM   #16
B.B._07
Drives: 07 5dr
The correct plugs to use in an 08 Yaris are Denso SK16R11 or NGK IFR5A11. There is nothing special about those plugs but the engine is designed to run best when using those plugs. You could use plugs other then the two listed but they have to be iridium tipped and in the same heat range. Iridium tipped plugs are pricey but they offer very long life (Toyota recommends changing the plugs at 120K or 144 months) and a very consistent spark. Old school inexpensive copper core plugs have the strongest spark but short lifespan, and platinum tipped plugs where developed before iridium to address the short comings of copper core plugs but have the poorest conductivity. I've found that putting platinum plugs in an engine designed for copper core plugs generally results in a engine running worse than before.
Old 06-08-2016, 11:47 AM   #17
fnkngrv
fnkngrv's Avatar
As another resource if you use Facebook there is my group there called "The Toyota 1NZ Enthusiast's Garage". I have several documents stored in the group and one of them for example is a whitepaper about spark plugs from NGK.
Anyway, I am actually officially sponsored this year by Autolite and from what I can tell they are a solid choice along with NGK. If you are running stock then I would stick with the Iridium as they are what the engine comes with.
Old 06-09-2016, 12:32 AM   #18
tarkus
tarkus's Avatar
I am using NGK Iridium IX plugs. While the OEM plugs, especially in the case of Toyota, will be good, we need to remember the car manufacturer is always making cost compromises. So with plugs, as with many other parts, you can get something a bit better if you don't mind paying a little more.
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
Changed Spark Plugs MyzticZ3r0 DIY / Maintenance / Service 4 11-14-2014 12:58 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
