Drives: Toyota Vitz 2008 Join Date: Jun 2016
Spark Plugs
What is the best spark plug for Toyota Vitz 2008?
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
re your question, best is a matter of category.
financial aspect: OEM is best other aspects: i have no idea, though i've tried Bosch platinum before, and it performed really well over OEM Honda plugs and costing only about US$1 more each ($3 vs. $2)--but that can also be because it's for a relatively older engine. |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
bosh platinum is a bad idea.
![]() OEM is a good idea. I'm also partial to denso TT spark plugs. |
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
Denso and NGK are normaly found as factory installed in our engines.
![]() Drives: Yaris 5 speed Join Date: Feb 2016
NGK iridium is the best.
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
I use NGK Iridium
Sent from my LG-D801 using Tapatalk |
I used NGK for all 5 but one the F150 can only do OEM Motorcraft, what a blow.
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Every 10,000k??? They're good for about 160,000 km
And why does being OEM make them better? I tend to think the opposite.
Mr. 155 and climbing
As another resource if you use Facebook there is my group there called "The Toyota 1NZ Enthusiast's Garage". I have several documents stored in the group and one of them for example is a whitepaper about spark plugs from NGK.
The Toyota 1NZ Enthusiast's Garage Anyway, I am actually officially sponsored this year by Autolite and from what I can tell they are a solid choice along with NGK. If you are running stock then I would stick with the Iridium as they are what the engine comes with.
I tend to agree. I would only not go OEM if they weren't readily available and you needed them immediately.
Sent from m-o-b-i-l-e
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The correct plugs to use in an 08 Yaris are Denso SK16R11 or NGK IFR5A11. There is nothing special about those plugs but the engine is designed to run best when using those plugs. You could use plugs other then the two listed but they have to be iridium tipped and in the same heat range. Iridium tipped plugs are pricey but they offer very long life (Toyota recommends changing the plugs at 120K or 144 months) and a very consistent spark. Old school inexpensive copper core plugs have the strongest spark but short lifespan, and platinum tipped plugs where developed before iridium to address the short comings of copper core plugs but have the poorest conductivity. I've found that putting platinum plugs in an engine designed for copper core plugs generally results in a engine running worse than before.
I am using NGK Iridium IX plugs. While the OEM plugs, especially in the case of Toyota, will be good, we need to remember the car manufacturer is always making cost compromises. So with plugs, as with many other parts, you can get something a bit better if you don't mind paying a little more.
I have traditionally changed mine on all my vehicles once a year. May be overkill, but it's what I do.
| New Spark Plugs, Engine Light Appear | grvdggr | Performance Modifications | 6 | 09-21-2015 09:34 AM |
| Changed Spark Plugs | MyzticZ3r0 | DIY / Maintenance / Service | 4 | 11-14-2014 12:58 AM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 08:02 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-01-2009 11:50 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
