Old 07-16-2017, 04:08 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
oil change - synthetic blend really?
the local o'reilly auto parts had a special oil/ filter for $19.99 so i decided to do a change before the maintenance light came on at 4500 miles
then when completed noticed "synthetic blend" on the label. Somehow i doubt its true only because the real synthetic oils ive seen advertised are much more expensive
and whats this "high mileage" note about? for engines over 75000 ....
Old 07-16-2017, 08:23 PM   #2
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
All I know is that I pit some of that in my old Rav4 and it started smoking on startup. I have no idea if it was a direct result of that oil, but it had never done that before. I had 76,000 miles on a 1999 Rav4. Those engines were known for that problem though.
Captain Yaris is offline   Reply With Quote
Old 07-16-2017, 11:23 PM   #3
That's not full synthetic. It's a blend of synthetic and conventional oil. I wouldn't use that for very long on your '16 since I believe full synthetic must be used. Also, I believe the manual calls for 0w-20 grade as well.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Recommend synthetic oil? Change at 3k or 5k caaront DIY / Maintenance / Service 36 03-02-2015 09:22 PM
Quick 2007 Yaris oil change question desidude DIY / Maintenance / Service 27 02-19-2015 05:54 PM
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
