![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Starting issue
For several months now the cars starter motor occasionally will continue to crank after the car has started. When it does this I turn off the ignition and restart. Then it is fine for a while until it acts up again. Any ideas on this abnormality?
![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
check the starter relay is off. It is located under the hood.
I like very much travel |
#3 | |
Proud Goloof Hater (G)
Drives: Toyota Yaris T1 Join Date: Jul 2012
I have a similar Problem with my 09 T1 LB. I have noticed the Starter motor acts up now and then and becomes sticky. do you switch off or stall the car occasionally, I think thats one of the causes. Wait for a few seconds then start the car up.. my opinion... I wouldnt really worry about it. I know the starter on that car is used on more cars than just a Yaris
They hear me before they see me-Pioneer 12" Champion Series Subwoofer -Targa 2000W 4 Channel amplifer - Sony Xplod GT45U Head Unit |
What do you think about this CT Scott?
Nic
Drives: 2008 3-Door Liftback Manual Join Date: Jan 2012
OK, I will add my 2 cents. I bought my 08 Yaris earlier this year. Not long after that, I had the starter stick when cranking. I found a thread on YarisWorld talking about it. A member suggested not cranking the Yaris like an older vehicle. Just turn the ignition and let go. The motor will turn over and crank without holding the ignition key. He was right. It was a little awkward at first, but now I am completely used to cranking it that way. I haven't had an issue since.
#6 | |
![]() Drives: 2002 Echo Join Date: Sep 2012
Looking at an 08 wiring diagram I cannot figure out how that would happen. Maybe the ECM takes control. I need to check this out further. Thanks for posting. My thought is that the starter relay or the starter solenoid is sticking keeping the starter energized. This is something I would check for a sticking starter. You can disable the engine from starting. Take a voltage reading of the battery for a reference. Then do a voltage test at the starter solenoid terminal while someone turns the key to start. With the key held to start you should read battery voltage. Once the key is released, the voltage reading should drop to zero. If you are still read battery voltage with the key released, the starter relay is sticking. If, with key released, the voltage goes to zero but the starter is still turning, the starter solenoid is sticking. This testing may change if what Nicfin posted holds true. Not sure how it would be diagnosed |
#7 | |
Drives: Yaris 2007 and 2012 Join Date: Nov 2018
Starter stick when cranking yaris 2007
Thanks I'll give it a try.
The Yaris, like most modern cars, have the feature to just click it to the "start" position and you can release it, and the car does the rest. It's like the PUSH button on most cars that have it. Just press it, and the ECU does it's thing (or whatever controls it).
But the issue does sound like a sticking solenoid switch (solenoid of the starter) |
Nic
I did not believe it at first either, but the starter has not "stuck" one time since I began cranking it the new way. I know there must be something to it, because I have an 08 Ford F150 work vehicle that does/did the exact same thing. I was cranking the Ford the old-fashioned way for about 4 years prior to me buying the Yaris and also encountered the "sticking" starter from time to time. I figured it was just par for the course on a Ford. Once I realized the Yaris cranked that way, I put two and two together and tried it on the Ford and now realize they crank the same. No problems on the Ford since I began cranking it like the Yaris.
Good info. I guess I am not up to date with these more modern cars. Always learning I guess. Will keep it in mind.
I do see the ECM wired into the starting circuit so it may be an ECM thing. Will try to learn more about it. Thanks. |
| Starting issue | tyrone_yaris | General Yaris / Vitz Discussion | 4 | 03-27-2012 12:16 AM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| 2009 Yaris starting issue -need help | cudchew | DIY / Maintenance / Service | 15 | 12-16-2011 02:24 AM |
| Weird starting issue 2007 auto yaris | Nask26 | DIY / Maintenance / Service | 11 | 07-28-2010 12:29 AM |
| Issue when starting.. | yaris prime | General Yaris / Vitz Discussion | 8 | 02-07-2010 01:29 PM |
