Old 03-26-2012, 03:22 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Starting issue
Hi,
I have the Vitz 2007 model, auto. I noticed since last week that after starting the car there is this choking sound for a few seconds, as if its struggling to continue running and then is normal. The car runs fine and no issue as such.
It only happens in the mornings after the car is parked for a long time say overnight and after work.
Any idea what is the cause?
Thanks
Tyrone
tyrone_yaris is offline   Reply With Quote
Old 03-26-2012, 08:24 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Does the starter sound normal? If you turn on your headlights and then try starting the car, how dim do the lights get before the car starts?
Old 03-26-2012, 01:11 PM   #3
tomato
tomato's Avatar
Battery?
Old 03-26-2012, 02:27 PM   #4
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
sounds like battery
caineroad is offline   Reply With Quote
Old 03-27-2012, 12:16 AM   #5
tyrone_yaris
Yes the starter sounds normal. Didnt try with teh headlights. Its only after I switch on the ignition that the struggling sounds happens and then its normal. Happens in teh mornings or late evenings after work when the car is parked for long in between it starts fine
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Weird starting issue 2007 auto yaris Nask26 DIY / Maintenance / Service 11 07-28-2010 12:29 AM
Issue when starting.. yaris prime General Yaris / Vitz Discussion 8 02-07-2010 01:29 PM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
