![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2017
Variable valve timing solenoid
Howdy folks! I'm fairly certain I have an issue with my VVT solenoid. I was tightening the serpentine belt and must have hit it by accident because immediately after starting the car the CEL was on and the code it gave was P0010. This seems to be a common problem from what I've been reading.
Rock Auto has half a dozen or so by different manufacturers and I'm just wondering if anybody has any input on which one would be the best option? They've got:
So does anybody have input as to which manufacturer might be better/more reliable? |
What you broke is the OCV (Oil Control Valve). I can't begin to tell you how many people have posted up here having broke it while prying on the alternator.
As far as replacement brands, can't comment. It is not an overly sophisticated part so I'd imagine almost anything on eBay, or whomever can get you the part fastest, would suffice. Sent from my EML-L09 using Tapatalk
#3 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Toyota call it the Oil Control Valve. Same thing. I'd probably get the OEM part from the dealer if mine broke or maybe get one from the scrapyard.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
huh. i'll have to look for this. i wonder how people are leveraging the belt. i am so trained to pry from the block i don't even know what is in the way.HA!
Afaik they are synonymous. Keep in mind you may have issues getting the old one out of the head. If that happens the worst case scenario is you can take off the valve cover and use a punch to push it out from the inside. Take more time but saves you from a trip to the mechanic.
When pulling it out from the outside it often comes apart and then you dont really have much the pull on anymore, just an fyi
#7 | |
#8 | |
![]() ![]() Drives: Toyota Yaris 2007 Sedan Join Date: Sep 2017
I replaced mine since in July last year. Not had a problem with it since. Got it from Aliexpress. https://s.click.aliexpress.com/e/hT1Im64 |
Serpentine belt adjustment, tensioning Mind of Toyota
Toyota manual says prybar-be-careful for belt adjust. I say 13 (14?) inch Chanelock pliers...1 jaw on alternator top bracket, other jaw on alternator's upper bolt boss.
| Check Valve Timing (On timing chain) | EMT with a Yaris | DIY / Maintenance / Service | 9 | 11-17-2018 03:29 AM |
| Valve timing help | Sakis Deme | General Yaris / Vitz Discussion | 0 | 10-17-2017 08:47 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Variable Valve Sensor Error | Craig | DIY / Maintenance / Service | 13 | 06-22-2013 03:29 AM |
