#145 | |
manual transmission oil
#146 |
Drives: 2009 red 2 door hatch yaris Join Date: Jul 2018
I just got a yaris 2 door hatch 5 speed with 105k miles and idk if the tranny oil has ever been changed it shifts nice never had a standard but i dont hear grinds or anything in mine the previous owner had it for 3 years and never mentioned trany oil change should i change it along with all fluids just to start fresh or would new oil mess up my tranny cuz its good i sort of cant stand not knowing if its clean or not and if its never been changed should damage happen to it???? Sorry for the long post 1st car and i wanna baby it good
#147 |
![]() Drives: 2010 Yaris Seden Join Date: Aug 2018
So I did my gear oil yesterday and I took the fill plug off first, and when I did oil started to pour out (less than a quart), did this happen to anyone else?
#148 |
That is fine it just likely wasn't overfilled before due to the front end being jacked up higher than you had it.
FWIW I over fill my trans fluid by about half a quart
#149 |
Not much came out when I did mine. Had a flat surface though.
Then poured 2qt in, small quantity came out and that's what I left it at. Sent from my VTR-L09 using Tapatalk |
#150 |
Yeah it wasn't much that I had pour out, it was up on jack stands. The worst part was that I wasn't anticipating it so I didn't have a catch pan ready at the time so I had to spend the next half hour trying to clean my friend's garage. I put in about to quarts on level ground afterwards and it seems to be doing fine, it shifts way smoother than before.
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 02:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 09:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
