#145 | |
Mr. 155 and climbing
Sent from my SCH-I545 using Tapatalk
#146 |
Just sources some Redline MT-90 from a local store near me for $21 a quart, not too bad a price. I'll be picking it up later this week and putting it in this weekend.
I get a slight quick grind when shifting into reverse in the morning in my driveway and I'm currently running 75w90 synthetic. Not much better than oem just a little thinner in the dead of winter. I'll leave my thoughts on here once I test it out.
#147 |
![]() ![]() Drives: Yaris 2008 HB Join Date: Sep 2007
GL-4 or GL-5 WHat's the difference. What's the verdict on what's best?
Thx |
#148 |
GL-4 seems to be what give much smoother shifting over GL-5. I've installed my GL-5 tranny fluid but haven't driven the car to try it out yet.
#149 |
What about Amsoil 75/90? It only comes in GL-5. Any suggestions?
http://www.amsoil.com/shop/by-produc...?code=SVGQT-EA |
#150 |
![]() Drives: 2009 Yaris 5-door Hatch Join Date: Feb 2016
Can transmission fluid just be added at the dipstick entry for auto?
Hi -
I have a 2009 5-door hatchback Yaris. Thanks for the great DIY instructions and photos - so helpful. Can I just add the Toyota transmission fluid there? Do I have to drain it? If so, can I drain it from the bottom, the same way as the manual? Thanks so much! |
#151 |
![]() Drives: 2008 2dr Yaris Hatch Join Date: Sep 2015
Thanks for this. I bought a 08 Hatchback a few months ago with a 5 speed MT with 65k miles. This was so easy and the shifting is much much smoother now. Only took 20 minutes, and most of it was waiting for the fluid to drain and for the fresh thick gear oil to flow down the tube.
#152 |
![]() Drives: Toyota yaris 2008 sedan manual Join Date: Mar 2015
please is Redline synthetic oil, API GL-4 Gear oil
SAE 75W80 manual transmission oil good for Yaris. |
#153 | |
#154 |
Drives: 2009 red 2 door hatch yaris Join Date: Jul 2018
I just got a yaris 2 door hatch 5 speed with 105k miles and idk if the tranny oil has ever been changed it shifts nice never had a standard but i dont hear grinds or anything in mine the previous owner had it for 3 years and never mentioned trany oil change should i change it along with all fluids just to start fresh or would new oil mess up my tranny cuz its good i sort of cant stand not knowing if its clean or not and if its never been changed should damage happen to it???? Sorry for the long post 1st car and i wanna baby it good
#155 |
![]() Drives: 2010 Yaris Seden Join Date: Aug 2018
So I did my gear oil yesterday and I took the fill plug off first, and when I did oil started to pour out (less than a quart), did this happen to anyone else?
#156 |
That is fine it just likely wasn't overfilled before due to the front end being jacked up higher than you had it.
FWIW I over fill my trans fluid by about half a quart
#157 |
Not much came out when I did mine. Had a flat surface though.
Then poured 2qt in, small quantity came out and that's what I left it at. Sent from my VTR-L09 using Tapatalk |
#158 |
Yeah it wasn't much that I had pour out, it was up on jack stands. The worst part was that I wasn't anticipating it so I didn't have a catch pan ready at the time so I had to spend the next half hour trying to clean my friend's garage. I put in about to quarts on level ground afterwards and it seems to be doing fine, it shifts way smoother than before.
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 01:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
