Old 02-23-2010, 09:53 PM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Exclamation This happen to anybody else?
so every now and then when I start it up the cluster is like REALLY dim to a point where I can barely see it....anybody else have this problem? this just started few months ago. took her to the dealership and they wanted $140 up front before they'd even look at it.....and btw what's the warrenty on this thing? they treid to tell me that it was out of warrenty
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 02-24-2010, 02:18 AM   #2
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Can you fix it by touching the dimmer knob? Move it back and forth a few times and see if it improves. Is your dimmer turned all the way to the end and locked in place?
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-24-2010, 02:30 AM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
$140 up-front? You better put your foot in their down-back for that offer!
For as long as I've known the base warranty is exactly one year after purchase date.
Old 02-24-2010, 02:45 AM   #4
Ryu
What he said.
Old 02-24-2010, 05:03 AM   #5
Qmobile
Qmobile's Avatar
see I tried fiddlin with the dimmer and no dice. and it is all the way up too......it's almost like the corners are on but they ain't just the runnin lights
Old 02-24-2010, 04:13 PM   #6
b_hickman11
Drives: 08 Sedan
36,000 miles or 3 years
Old 02-24-2010, 04:15 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
check your grounds and fuses.
and tell us EVERY modification that's been done to your car. aftermarket parts are the number 1 cause of factory part failure lol
Old 02-24-2010, 04:30 PM   #8
Is the illumination of the AT shifter and AC Controls dim as well?
If they are all dim, check the GAUGE fuse. If just the speedometer is dim, check the MET fuse.
Old 02-24-2010, 11:07 PM   #9
Qmobile
Qmobile's Avatar
I'll have to check that cuase it's just the speedo
Old 02-25-2010, 01:14 PM   #10
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If its not under warranty find an honest mechanic, if it is under warranty find another dealer even if it means going all the way to Toledo,whatever you do dont go back to your current dealer as he's just out to screw you..
how can i make this happen? ryota Cosmetic Modifications (Exterior/Interior) 10 10-01-2009 06:26 AM
I knew this would happen Arkhangel Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 04-29-2009 11:05 PM
What would happen if i disconnected this wire??? Syroyizhka General Yaris / Vitz Discussion 21 04-06-2009 10:06 PM
wat happen if u ebrake going 80mph? Blenjar Off-topic / Other Cars / Everything else Discussions 29 06-15-2007 10:09 PM
i happen to have a 1.8 fuel injector critical Performance Modifications 3 03-12-2007 11:57 PM
