Old 03-30-2010, 08:52 PM   #1
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
any how to's to disengage the traction control?
any1 tried ? any help will be appreciated
OTA'sTOY is offline   Reply With Quote
Old 03-31-2010, 05:15 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Be aware you'll probably disengage your warranty at the same time.
Old 03-31-2010, 12:58 PM   #3
markitect
Drives: Yaris
In the US it's illegal to deny warranty coverage unless something you did directly damaged something.
That said, if you insurance company thinks they are covering a car with traction control, and you get into an accident and they find out you disabled it they can deny you coverage. Although if you can find the proper fuse, blow it and put it back in, and don't post anything on here, they can never prove that the fuse didn't blow during said crash.(I have no idea which fuse would do it, or what else removing said fuse could disable.).
markitect is offline   Reply With Quote
Old 03-31-2010, 10:41 AM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Did you check your owner's manual to see if there is a method to turn it off?
Old 03-31-2010, 05:11 PM   #5
severous01
pull e-brake one click
it wont engage the brake but it'll disengage ABS and traction
Old 03-31-2010, 06:16 PM   #6
Which Yarii have traction control? Mine doesn't.
Old 03-31-2010, 07:40 PM   #7
Loren
What?
Loren's Avatar
ABS/traction control/stability control
Standard for 2010
Old 03-31-2010, 11:14 PM   #8
127.0.0.1
how about using the search feature ?
I wrote up the method, and others have also.
Old 04-06-2010, 04:26 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Traction control on 08 - back off the gO pedal ;)
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Traction Control ??? pennystocks General Yaris / Vitz Discussion 6 09-12-2006 07:14 AM
