Old 04-30-2010, 01:14 PM   #1
FS: Push to Start Trim Piece
I bought a batch of these "Push To Start" trim pieces from Europe. These are used on European Liftbacks, which have the Push To Start feature. They fit perfectly with the JDM Vitz, Camry, Avalon, or Lexus PTS switch.
I bought enough to get a reasonable discount, so these are $30 shipped.
Here are some pictures of the piece and of one in my 09 Liftback with a JDM Vitz PTS switch installed.
CTScott is offline
Old 04-30-2010, 01:20 PM   #2
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
wont fit a sedan huh?
Aothachos is offline
Old 04-30-2010, 01:26 PM   #3
No. I believe that the only sedans that have Push Button Start are right hand drive.
CTScott is offline
Old 04-30-2010, 01:20 PM   #4
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
How hard is it to wire up the actual button?
schleppy is offline
Old 04-30-2010, 01:36 PM   #5
I created a module that works with the OEM Engine Start/Stop Switch, and lets the switch start and stop the engine (and it drives the LEDs on the OEM switch).
There are 5 wires that connect between the switch and the module, 3 wires that connect to the ignition switch and one wire that gets tied to chassis ground.
Here's a video of the switch in action, which also explains the installation:
http://www.youtube.com/watch?v=v6zinlD58Eg
CTScott is offline
Old 05-23-2010, 03:32 AM   #6
kazama82
Drives: VIOS
Attachment 33598
hi scott, will this module work with yaris sedan?..how much to shipped to Malaysia?
kazama82 is offline
Old 05-24-2010, 08:44 PM   #7
kazama82
Drives: VIOS
kazama82 is offline
Old 05-24-2010, 09:23 PM   #8
It definitely would work with a Malaysian Yaris. Shipping would be $10 to Malaysia.
CTScott is offline
Old 04-30-2010, 03:08 PM   #9
custom Lftback
custom Lftback's Avatar
So how much would it be for the whole set up? (trim piece, push to start button, and the module)
C-Lift
custom Lftback is offline
Old 04-30-2010, 03:19 PM   #10
Trim: $30 shipped
Module: $55 shipped
Switch: $35+ on eBay or ~$70 from your local dealer
The switch connector and pins are expensive from the dealer and hard to find from junkyards, so it is most cost effective to solder to the pins. If you purchase a switch and ship it to me I will do the soldering to the module wires (with an inline connector to make installing it easier) for no extra charge.
The picture above of the module and switch is an example of a direct wired switch - That one is alainmikli's TRD PTS switch, which I assembled for him last weekend.
CTScott is offline
Old 05-26-2010, 04:42 PM   #11
PhillyG
Drives: 2009 Yaris
Trim: $30 shipped
Module: $55 shipped
you still willing to do the connections if i can find a switch ans ship it to you? got a part number for the switch?
PhillyG is offline
Old 05-26-2010, 10:05 PM   #12
Yes.
Vitz Japan/Corolla Japan/Rav4 Japan: 89611-52020
Vitz Japan/Corolla Japan/Rav4 Japan: 89611-52021
Yaris Europe: 89611-0D010
Camry/Highlander/Land Cruiser Japan: 89611-52011
Camry/Avalon USA: 89611-07010
CTScott is offline
Old 04-30-2010, 09:10 PM   #13
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Great Scott!! This is a great deal for an OEM trim piece with shipping!!
If I had the extra funds laying around, I'd definitely do this!!
Bump!!
Sponsored by: Micro Image
http://microimageonline.com
TEHxFALLEN V1.2 is offline
Old 05-03-2010, 09:25 AM   #14
TKO
Drives: 4 door hatch
Would you happen to know if your start button would work in a 06 Scion xA?
TKO is offline
Old 05-03-2010, 04:13 PM   #15
I am not sure if the switch would be the same for the xA, but my module should work the same on an xA.
CTScott is offline
Old 05-08-2010, 09:29 PM   #16
Mistry
Mistry's Avatar
Drives: Red Yaris Liftback
Would your module work even if the yaris has a remote start installed?
Mistry is offline
Old 05-08-2010, 09:41 PM   #17
Yes. I recently made some changes to how I determine that the car is started to allow it to work properly with remote start.
CTScott is offline
Old 05-08-2010, 10:15 PM   #18
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Just as a heads up when you pull the right hand trim piece off from the center console there is a round hole which looks to be that size to accommodate the push to start mechanism. I was going to use that hole for another project however this has my mind moving in a different direction. All one with a sedan would have to do is punch out the correct size hole and then would be able to mount the PTS I would wager.
Any insight or ideas on this CTScott?
fnkngrv is offline
Push Button Start Stoln Europe (continental) 20 05-24-2010 07:56 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 14 09-25-2009 12:21 AM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 02:37 AM
Canadian DD trim piece. Can any of you Canadian members get one? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 12-20-2008 12:52 AM
