that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
after looking at the sticky about this I'm still confused what sizes I need for lights. I wanna change most(if not all) of my lights to LED. Here's what I've understood so far, correct me if I'm wrong:
Dome light: 30022 (32mm) Truck/cargo: 3610(36mm) Rear turn: 7507A tail/break:7443 remember I got the hatch also. I'd like to at least do those light in LED and the reverse and l-plate lights too. My plan (for the tails) is to first do the stockers then do the TYC tails I got. Now you may be asking yourself "why both sets?" or "Why at all?" well.......LEDs are cooler, brighter and take up less power. And I wanna do both sets so if something happens to one of I'll have a back up.
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
That thread definitely has some faulty info. Turns out the map lights and license plate illumination lights are the same (for the sedan atleast). That sticky has the illumination lights listed as the same as dome ones... and they're most certainly not.
hmm a dealer should have all this info too right? I mite have to stop by sometime. Good thing I 'm in good terms with my dealer's part dept
. CLA 250, 4MATIC |
you need wedge for the map, a 36mm festoon for the hatch and a 31mm festoon for the dome...sedans use a wedge for the trunk
i have some for sale in my FS post in the classifieds....PM'd you
#6 | |
![]() ![]() Drives: 2011 Yaris 3-Door Hatch white Join Date: Feb 2010
#8 | |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
I picked up a set from thebarber a while ago, they look great. |
is that list for regulay bulbs or LEDs? maybe I'm thinkin wrong I'm wantin to change to something brighter, take less power to run and is direct replacement. I epsaclly want bright for the clear tails
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I changed my lic. plate light because I didn't want to risk getting pulled over when the OEM bulb burnt out. Although I may replace it because it only has 1 LED and isn't very bright. Legal, but not that bright.
but am I thinkin in the right direction? I seen not too long ago direct replacement LED bulb or whatever u wanna call it in red
ok....noted
#14 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Keep in mind, that electrical gremlins likely will pop up if you convert entirely to LED, as the amperage draw is infinitely smaller than standard incandescent bulbs.
#15 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
What kind of gremlins?
#16 |
yes! please tell me....err us about these gremlins you speak of.
#17 |
#18 |
ok here's what I just found out! I looked at the sockets for the bulbs in the TYC tails, and found some numbers. maybe bulb sizes or it the part # for the actual housings? Anyway here:
Break-f115 Turn-f116 Reverse-f58 And idk if the stock tails have this but with these there's a extra bulb that faces to the side of the car(when installed) witch had no number or anything. So what are these numbers that I found?
| Door Handle LED DIY with pics | window_lee | DIY / Maintenance / Service | 93 | 06-01-2012 12:58 AM |
| DIY LED Strip under the door panel | charleschia1986 | DIY / Maintenance / Service | 19 | 11-05-2011 08:49 PM |
| Interior LED Ricey Problem | xbr3akd0wnx | Cosmetic Modifications (Exterior/Interior) | 10 | 05-06-2010 09:50 PM |
| Cheap eBay LED Strip vs V-LED Strip | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 1 | 03-18-2010 09:06 PM |
| FS: JDM Modellist II Front bumper & JDM LED tails | DKN-YARIS | Items for Sale by private party | 7 | 11-09-2008 02:10 AM |
