Old 07-07-2010, 02:58 PM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Lightbulb going LED
after looking at the sticky about this I'm still confused what sizes I need for lights. I wanna change most(if not all) of my lights to LED. Here's what I've understood so far, correct me if I'm wrong:
Dome light: 30022 (32mm)
Truck/cargo: 3610(36mm)
Rear turn: 7507A
tail/break:7443
remember I got the hatch also. I'd like to at least do those light in LED and the reverse and l-plate lights too. My plan (for the tails) is to first do the stockers then do the TYC tails I got. Now you may be asking yourself "why both sets?" or "Why at all?" well.......LEDs are cooler, brighter and take up less power. And I wanna do both sets so if something happens to one of I'll have a back up.
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 07-07-2010, 03:06 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
That thread definitely has some faulty info. Turns out the map lights and license plate illumination lights are the same (for the sedan atleast). That sticky has the illumination lights listed as the same as dome ones... and they're most certainly not.
Old 07-07-2010, 03:12 PM   #3
Qmobile
Qmobile's Avatar
hmm a dealer should have all this info too right? I mite have to stop by sometime. Good thing I 'm in good terms with my dealer's part dept
Old 07-07-2010, 04:21 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Can you read this?
and/or use this LINK
I have LEDs all around but turn signals and revers
CLA 250, 4MATIC
Old 07-07-2010, 05:58 PM   #5
you need wedge for the map, a 36mm festoon for the hatch and a 31mm festoon for the dome...sedans use a wedge for the trunk
i have some for sale in my FS post in the classifieds....PM'd you
Old 07-07-2010, 07:48 PM   #6
Qmobile
Qmobile's Avatar
Can you read this?
just barely can read it
Old 07-07-2010, 07:52 PM   #7
Qmobile
Qmobile's Avatar
is that list for regulay bulbs or LEDs? maybe I'm thinkin wrong I'm wantin to change to something brighter, take less power to run and is direct replacement. I epsaclly want bright for the clear tails
Old 07-07-2010, 07:55 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
I changed my lic. plate light because I didn't want to risk getting pulled over when the OEM bulb burnt out. Although I may replace it because it only has 1 LED and isn't very bright. Legal, but not that bright.
Old 07-07-2010, 07:58 PM   #9
Qmobile
Qmobile's Avatar
but am I thinkin in the right direction? I seen not too long ago direct replacement LED bulb or whatever u wanna call it in red
Old 07-07-2010, 08:52 PM   #10
Both.
Old 07-07-2010, 11:49 PM   #11
Qmobile
Qmobile's Avatar
ok....noted
Old 07-08-2010, 04:17 AM   #12
Damo
Drives: 2011 Yaris 3-Door Hatch white
Hold down CTRL and scroll your mouse wheel :)
Damo is offline   Reply With Quote
Old 07-08-2010, 06:56 AM   #13
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Keep in mind, that electrical gremlins likely will pop up if you convert entirely to LED, as the amperage draw is infinitely smaller than standard incandescent bulbs.
Old 07-08-2010, 07:23 AM   #14
sickpuppy1
Drives: 2010 Yaris Sedan
What kind of gremlins?
Old 07-08-2010, 04:19 PM   #15
Qmobile
Qmobile's Avatar
yes! please tell me....err us about these gremlins you speak of.
Old 07-08-2010, 09:46 PM   #16
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I picked up a set from thebarber a while ago, they look great.
goliath1812 is offline   Reply With Quote
Old 07-10-2010, 02:43 AM   #17
Qmobile
Qmobile's Avatar
ok here's what I just found out! I looked at the sockets for the bulbs in the TYC tails, and found some numbers. maybe bulb sizes or it the part # for the actual housings? Anyway here:
Break-f115
Turn-f116
Reverse-f58
And idk if the stock tails have this but with these there's a extra bulb that faces to the side of the car(when installed) witch had no number or anything. So what are these numbers that I found?
Old 07-14-2010, 06:44 PM   #18
Qmobile
Qmobile's Avatar
bump!
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 06-01-2012 12:58 AM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 08:49 PM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 09:50 PM
Cheap eBay LED Strip vs V-LED Strip Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 1 03-18-2010 09:06 PM
FS: JDM Modellist II Front bumper & JDM LED tails DKN-YARIS Items for Sale by private party 7 11-09-2008 02:10 AM
