Old 01-11-2012, 09:17 PM   #1
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
Where are the tweeters
Where are the stock tweeters located ? I want to replace them with some aftermarket ones that I got . Are they replaceable? Will I notice a difference?
400 dollar yaris is offline   Reply With Quote
Old 01-11-2012, 09:32 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
As far as I know, they don't exist. There are several threads here where people have modded their A-pillars to put them in.
Old 01-11-2012, 10:22 PM   #3
400 dollar yaris
Ok so how hard is it to wire them up to the head unit ?
Old 01-12-2012, 08:10 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Why would you wire the tweeters next to the head unit?
But yes, as mentioned, the a-pillars are one of a couple spots that you would place tweeters to improve the sound.
― Thomas Paine
Old 01-16-2012, 05:53 AM   #5
yojabbajabba
Drives: 2008 YRS 5Dr LB (1.5L)
Where would the other spot(s) be SQ? Considering in a thread somewhere you suggested that tweeters should be <1 foot from your woofers (something to do with time delay minimisation), I can only think of installing tweeters on the side of the window up-down controls on the door panels.
yojabbajabba is offline   Reply With Quote
Old 01-12-2012, 02:56 PM   #6
TOLMACH
Drives: soarer
Look how some people installed their tweeters in the doors (tweeters facing the ceiling) - probably not the best placement but in this case it would be easy for you to get them installed and wired.. as you will use the hi level speaker cables that go to the woofers in the front doors (you will then @split@ this signal into signal for tweeters (high pass section of your netwrok) and signal for woofers (low pass filter of your crossover network will be used))
what you can do is to find tweeters and 2-way crossover networks (try to use 4 ohm tweeters and networks that were designed for 4 ohm speakers) from some set that you can install in the doors as well (hide them somewhere within the door)
woofers in the front doors are OK
yes, adding tweeters and installing / wiring them correctly will strongly improve the overall SQ
tweeters in door centrysis In Car Entertainment + Electronics (audio / video / alarm) 10 06-04-2010 11:01 AM
For trade SEDAN ONLY tweeters mounted on the door sails looking to swap read more ins YarisSedan Items for Sale by private party 6 03-16-2010 02:40 AM
Best place to mount tweeters in the LB? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 20 01-18-2010 11:45 PM
Powering/Installing Tweeters? eii In Car Entertainment + Electronics (audio / video / alarm) 1 01-12-2010 09:00 PM
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
