Old 06-02-2010, 09:06 PM   #1
centrysis
centrysis's Avatar
Drives: '08 Yaris LB
tweeters in door
I've been running polk components in the back of my 08 HB. I finally got the other pair for the front. I've seen people mount the tweeters at the top of the door. After trying different places, they did sound good there. Pulling wire through the boot in the door was a pain until I greased up the wire puller.
After mounting the mids, which actually cleared the window with fatmat behind the speaker bracket, and mounting the crossovers behind the glovebox,
I drilled the holes for the tweeters
The panel under it looked like this when I started
and this when I got done modifying it
I mounted the brackets for the tweeters
and put everything back together
They do sound good here, and they're protected a little from the rain if the window is down. Next step will be to deaden the doors when I can get more mat and then a custom box in the back. Right now I'm running two 12" sony's that are about 6 years old. Sorry for the crappy photos. I had to use my phone.
centrysis is offline   Reply With Quote
Old 06-02-2010, 11:20 PM   #2
djct_watt
Drives: 2010 NCP91 5spd
It's not when you open your window that you have to worry, it's when you open your door. If you get heavy rainfall, they will probably see damage. With they amount of rain I see in out here in Thailand, that area gets SOAKED, just from briefly opening the door. I have no idea about Ohio though. . .
djct_watt is offline   Reply With Quote
Old 06-03-2010, 12:09 AM   #3
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Nicely done! Nothing like a little lube!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 06-03-2010, 12:55 AM   #4
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
[IMG][/IMG]
[IMG][/IMG]
pennyracer is offline   Reply With Quote
Old 06-03-2010, 08:45 AM   #5
centrysis
centrysis's Avatar
I like your setup alot, but I'm not that talented Pennyracer.
Old 06-03-2010, 09:45 AM   #6
pennyracer
boydstir
pennyracer's Avatar
thank you thats only part of my system those are focal 3 ways in my doors :) [IMG][/IMG]
[IMG][/IMG]
Old 06-03-2010, 11:07 AM   #7
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Both jobs look fantastic.
@pennyracer: how'd you do those mouldings for the doors?
Old 06-04-2010, 01:37 AM   #8
pennyracer
boydstir
pennyracer's Avatar
they are hand made
Old 06-04-2010, 03:09 AM   #9
IsLNdbOi
IsLNdbOi's Avatar
Wow. Good job hijacking the thread with your beautiful work.
Now, can you make those door pods for other LB owners?
Old 06-04-2010, 08:39 AM   #10
centrysis
centrysis's Avatar
I do want to get two subs mounted in the back like that. I might be able to do that. My box I have now takes up the whole hatch area.
Old 06-04-2010, 11:01 AM   #11
pennyracer
boydstir
pennyracer's Avatar
ya most people go the route not me i need all the room i can i can bounce around a case of water when i crank it up so no problem with running the cover on it plenty of base i am willing to sell this setup if someone wants it ? i built it to be taking out without any problems plug and play my sub floor is i want to build a sub floor with 4 tens this time in the very same style i have let me know if you interested ? keep up the good work [IMG][/IMG]
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
For trade SEDAN ONLY tweeters mounted on the door sails looking to swap read more ins YarisSedan Items for Sale by private party 6 03-16-2010 02:40 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
