Old 03-14-2012, 05:04 PM   #1
JonS
Drives: 2009 3 door Liftback
Front brake clunk after reversing
Hey all,
I've noticed that when I reverse and then apply the brakes, there's a clunk sound coming from the front end (brakes?). Is this normal or is something getting loose over time?
Thanks for any ideas,
Jon
JonS is offline   Reply With Quote
Old 03-14-2012, 05:59 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Is it a clunk or a grating noise? If it's the latter, that's a condition of brakes on an automatic. because braking is almost always done going in a forward motion, the brake disk is kind of "smeared" in one direction by the frequent braking while it is rotating counter clockwise (or clockwise, on the passenger side). When you brake going backwards the pads are now working against a grain, like cheese over a cheese grater. Hence the noise.
Old 03-14-2012, 08:46 PM   #3
JonS
No, it's just a cluck. Could it be the calipers?
Old 03-14-2012, 08:59 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If one of the pistons is jammed, perhaps. Hard to diagnose unless you're familiar with brakes.
Try a test. Reverse, and while you still have momentum, brake.
Then, try reverse, then after you come to a stop (with no backward momentum), brake.
Old 03-15-2012, 02:54 PM   #5
Em_
Drives: 2007 Yaris
nothing to worry about it's just the pads hitting the caliper when going backwards
your pads are supposed to have U shaped shim on top if that shim is crushed or missing it would cause the noise
Em_ is offline   Reply With Quote
Old 03-15-2012, 08:17 PM   #6
JonS
Thanks for all the input. After searching around the net, as well, it seems it is probably just the pads shifting. I'll just keep an ear out for if the clunk gets louder, etc.
Thanks again,
Jon
Old 03-21-2012, 11:02 AM   #7
llimonce
Drives: yaris sedan
just put grey gasket silicone in the pad`s ears and voilaaa!! excuse for my english :-)
see my image
llimonce is offline   Reply With Quote
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
