![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
URGENT: Help Drum/Parking Brake problem
Hey guys, I recently bought a used 2007 Yaris Sedan
I noticed that the rear brake squeal after I used the brake a lot and a minor squeak when i sit in the car. I confirmed that the rear drums were completely locked even though the hand brake was down. I tried to adjust it, but it just becomes locked again. I noticed that the parking lever in the brake assembly is very sticky, as in it won't retract properly. I'm a total noob at drum brakes. Can you guys share how to fix this? Thank you! |
Also pix of a correct drum brake of a Yaris would be great. The service manual doesn't depict it well. Specifically, I need a view of the parking lever untensioned.
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
< threadjack >
Scott, do you just have pics like this laying around, or do you take them on demand when things like this pop up? ;0) < /threadjack >
I took them when I had the drums off for painting. I figured that eventually either myself or someone else would need them for reference.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I hereby add a reminder to my phone: "Nobel Candidate that man".
Hey CTScott, thank you very much!
I checked over, and everything looks like in the same place. I've seen other toyotas and other cars really with a parking brake return spring. It seems that the Yaris doesn't have one... Is this a common problem in the Yaris? I live in SoCal. No rust on the car. |
#8 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
With the drum off, pull the parking brake handle enough to move the lever (#1). Then release the parking brake handle (lower it) and inspect the cable (#2). If the cable is straight and taut, the cable is the problem (does not extend). If the cable is curved and slack, the lever is stuck. If a cable you generally just replace them. They can be lubed, but usually with limited success. If the lever is stiff you will have to take the brakes apart and clean/lube. Hope this helps. |
You're awesome Cory! Yes, I did notice that when I was operating the brake. I noticed that the cable was bent a little when hand brake was released. I sprayed some cleaning brake clean onto the whole assembly and that seems to take care of it, for now at least...
I noticed that on this drum assembly, it doesn't have a dedicated lever return spring as with other cars. Again, definitely appreciate it Cory. |
This is awesome because mine do not adjust much, at least one side anyway, causing the car to not stop correctly after about a month or two.
What should I use to clean everything next time I take them apart? |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| rear brake light problem | kaazio | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 02-11-2011 05:27 PM |
| Brake pedal vibrates-not rotor problem | rradhay | DIY / Maintenance / Service | 9 | 11-12-2010 09:10 AM |
| Brake problem | 1saneguy | General Yaris / Vitz Discussion | 15 | 11-24-2008 03:56 AM |
