Old 11-24-2015, 11:25 AM   #1
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
Hard-to-crank manual windows
The manual-crank windows on my 2012 Yaris are becoming extremely difficult to roll up and down. The driver's window has gotten to the point where I am afraid I am going to rip the window crank knob off. Seriously.
As a test, I sprayed a small amount of WD-40 into the side channels, and the window immediately became much easier to roll up and down. This lasted about a week before they became difficult again. I am concerned that continued use of WD-40 is not the appropriate procedure for this issue.
Has anyone else suffered with this condition? Is there anything that can be done at home instead of making an appointment at the dealership?
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 11-24-2015, 06:22 PM   #2
nortonfb
Drives: 2007
For window channels silicon spray is what the shops use.
I would look at the crank itself. I'm guessing it's binding on he plastic weather seal.
nortonfb is offline   Reply With Quote
Old 11-25-2015, 07:24 AM   #3
bronsin
bronsin's Avatar
Because the WD40 made the window work perhaps all that's needed will be a suitable lube like the silicon nortonfb mentions.
Old 11-25-2015, 08:25 PM   #4
YarTed
Drives: 2015 Yaris 5Dr
WD40 would be long term harmful for the rubber in the tracks. I would use silicone spray its the right product for this type of use. ... my thoughts
YarTed is offline   Reply With Quote
Old 12-10-2015, 12:12 PM   #5
mirapatec
mirapatec's Avatar
Thanks nortonfb, bronsin, and YarTed! I appreciate your advice.
Update: After a week or so of testing, the silicon spray appears to be doing the trick. I have no idea why this extra lubrication was needed so early in the life of my Yaris, though.
Old 12-10-2015, 05:47 PM   #6
nortonfb
Drives: 2007
I had a BMW 318 TI that would require a once a year spray. If it didn't get it
the window regulator would bend. Nasty job that always drew blood.
Glad it worked out for you.
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 10:02 PM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) Hershey Off-topic / Other Cars / Everything else Discussions 7 09-30-2011 10:54 AM
crank, fire, hesitate, crank, fire, run, gas smell twowheels General Yaris / Vitz Discussion 9 06-25-2009 07:11 PM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
