![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Lowering springs on stock shocks? 1 inch?
Hi all. Looking to finally lower my 09 Yaris Sedan. But I only want to go down about 1 inch, or 25.5mm. Will this be a problem on stock shocks? I don't know how low you can actually go using stock shocks/struts. Well the front 2 are KYB brand replacements, but they're meant to be like stock according to KYB. Lastly, which springs would you use for this task?
Best bet is probably TRD or Eibach springs.
Not gonna harm the shocks or the ride any? I was trying to make sure I avoid messing up the shocks/struts.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I have Tanabe DF210 springs on my 2010 sedan. It gives about a 2 inch drop, which is ok except on some speed bumps in parking lots, and even then I'm ok as long as I go slow.
The NF210 is about 1-1.5 inch drop and rides a little better so they say. Mine is slightly stiffer than stock,but not bad at all. I love them!! Oh and I'm on stock 185/65-15 tires |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
I lowered my 07 Sedan at 130k miles. Dropped it 2” on stock struts with Tein S springs. I’m at 212k miles now with no issues whatsoever. DROP IT!!!
TRD or Eibach Prokits will work well with stock shocks. I wouldn't forsee any abnormal wear.
All this does is change the height, right? Do I need to get an alignment afterwards? Have toe/camber adjusted? Again trying to do only the 1 inch.
#8 | ||
Any lowering spring will alter the ride quality as they're stiffer springs compared to the OEM springs. Also, any lowering springs will reduce the lifespan of the dampers (shocks). So if your car already has some higher mileage to them, you'll have to pull out the suspension twice (once for installing the springs, and another to replace the dampers when they blow). Any adjustment to the ride height will require an alignment afterwards. Only the front of the Yaris is adjustable. The rear are not unless you use shims. If all you're looking for is an inch drop and you have higher miles on the car (means most likely the dampers are nearing the end of their life), I would suggest getting some basic coilovers like the Tein Basis Z. They're basic coilovers in that they don't have dampening adjustment, but at least the dampers are valved/paired correctly for the spring rate. And you can dial in just how much lowering you want (within the range it provides, which is a little under an inch min to a little under 2 inches max). |
#9 | |
Additionally, I prefer the ride quality after lowering with Tein S. Tech springs than when running stock springs. The Tein's offer a progressive spring rate so it's very nice around town and then sits down under heaving turning. I agree that the Tein Basic's are a good option, but if someone is looking at the budget and has functioning factory shocks/struts, I wouldn't be that concerned about lowering with springs and keeping the OEM shocks/struts for a while. Just my 2 cents. |
For a mere 1" drop, just swap in the new springs. No real need to worry about dampers, shims, camber, toe, etc.
Thanks all! I'll post pics when I'm done. I've inherited this car as a new work car. Yaris is now actually mine full time. So I'm gonna mod it to my liking.
That said, what headlights are high quality enough to replace the oem ones? The car is that black metallic color, so dark colored headlights wouldn't be unwelcome. Just don't want to end up with some cheap junk. |
#13 | |
#14 |
Well to clarify, I was referring mainly to stuff that wouldn't leak and were somewhat durable when it comes to hazing over after a year or two. Although I think I've found a way to permanently defeat the hazy headlights. Applying this sealer once per year:
https://www.amazon.com/Meguiars-G178.../dp/B01M4RVVX6 |
#15 | |
Def stay away from aftermarket headlights then. Those tend to have over much quicker. I just wax my headlights every so often to help prevent them from hazing. |
#16 |
step by step, toungue out
Drives: 1NZ-FE MarkI Xp10 Yaris coupe Join Date: Sep 2018
Hey buddies, i just register my self to yarisworld, i've searching info, but there's any clue on web about springs swap, you see, i just bought this 2002 Yaris XP10, recently adding some muscle on it, it came with 2ZN but i just swapped for a 1ZN-FE, no boost, nos charge, just another engine.
After 3 weeks of walkaround, its claiming for a suspension upgrade, i was looking for an set of aftermarket coil springs, but i just cannot find any, so, today i found this guy who is selling me a set of TRD springs, the doubt appears comparing to my set of oem springs, cuz, those TRD says that it's for XP90/XP130, please, let me know if these TRD fit on my XP10, it seems great, i think that it fit. Can i use XP90 TRD Springs on my XP10? i really apreciate your comments. |
| Please post pics of your Yaris with aftermarket rims here | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1800 | 11-12-2025 12:57 PM |
| TRD Sport Shocks, Lowering Springs & Sway Bar | Blue Beast | Cosmetic Modifications (Exterior/Interior) | 18 | 10-29-2012 04:39 AM |
| fs stock springs and struts, shocks | XyresicPsych | Items for Sale by private party | 10 | 05-04-2012 08:34 PM |
| for trade lowering springs for stock rs 2007 | mfvantol | Items for Sale by private party | 5 | 09-24-2011 08:30 PM |
| TTE / Eibach springs + stock shocks & 15" wheels | DieselPower | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 07-11-2009 02:42 PM |
